solid CEL 96 dx auto to 01 ITR swap tried diff ecu's
Old Oct 30, 2006 | 09:26 PM
darrinbrewer's Avatar
Default solid CEL 96 dx auto to 01 ITR swap tried diff ecu's
got a solid CEL, tried 2 different chipped p28s, its my freinds car,
a 96 dx auto, converted to a auto vtec a few years ago, and now a 01 ITR swap the past few weeks.(with obd2>1 harness)
it runs almost normal, vtec works, redline is right..
car bucks really bad at part throttle, and forget 5th gear cruising
it bucks so bad pulling out easy, that the tires go , CHIRP!, CHIRP!
i put my own ECU in there(known good), reusing his chip, still same SOLID CEL
the whole swap with same ECU worked for a year or so in the type r, it got rolled over, and the motor swapped to the forementioned hatch.
sometimes idleing, it will fluctuatle VERY fast, then go normal(up and down 2-3 times a second) not the rev up, then fall, rev up then fall, i mean FAST!
car shows being in gear 2 all the time on the auto dash, but has done that since the auto vtec swap a few years ago
iacv was converted from 3 wire to 2 wire already
any idea's appreciated
Modified by darrinbrewer at 6:05 PM 10/31/2006
Old Oct 30, 2006 | 09:45 PM
Timmay's Avatar
Default Re: solid CEL 96 dx auto to 01 ITR swap tried diff ecu's (darrinbrewer)
im going through a simmilar problem 96-98 civic with obd2-1 conversion
im down to either bad distributor or bad conversion harness
try a obd2 ecu and see how it idles.. like a p2p EX one just to plug in and idle maybe drive partial throttle
Old Oct 30, 2006 | 10:04 PM
Luserkid's Avatar
Default Re: solid CEL 96 dx auto to 01 ITR swap tried diff ecu's (Timmay)
Did you guys change from 3wire IAC to 2 wire? If not that could be your problem.
Old Oct 31, 2006 | 08:09 AM
Default Re: solid CEL 96 dx auto to 01 ITR swap tried diff ecu's (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">Did you guys change from 3wire IAC to 2 wire? If not that could be your problem. </TD></TR></TABLE>
this motor and ecu ran fine the ITR, then pulled motor swap and ecu and put it into the 96 hatch, using same conversion harness and ecu., using a 96 ex motor harness.
is there a teg/ civic iac problem with 3 wire/ 2 wire or something?
Old Oct 31, 2006 | 08:22 AM
Sloshy's Avatar
you need to the fix make it a two wire and itll run properly
Old Oct 31, 2006 | 12:26 PM
Timmay's Avatar
Default Re: (hatch-E-vanish)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatch-E-vanish &raquo;</TD></TR><TR><TD CLASS="quote">you need to the fix make it a two wire and itll run properly</TD></TR></TABLE>
he is using a ex harness its 2 wire
Old Oct 31, 2006 | 02:04 PM
Default Re: (Timmay)
i asked, it was converted from 3 wire to 2 wire already
Old Oct 31, 2006 | 02:52 PM
Timmay's Avatar
Default Re: (darrinbrewer)
if its a ex harness its 2 wire stock
ej8ster96
May 16, 2010 07:40 PM
bonies
24
Aug 30, 2009 11:00 PM
EGandDArida
11
Oct 1, 2008 07:49 AM
awalp
Oct 6, 2007 05:57 AM
lmfreestyler
13
Jun 21, 2006 06:22 PM
