I need to get a new speedo cluster for my 94 si does it have to be from a 94 or can it be something
Old Oct 30, 2006 | 06:55 PM
steelrainwarrior's Avatar
Default I need to get a new speedo cluster for my 94 si does it have to be from a 94 or can it be something
Old Oct 30, 2006 | 06:58 PM
Default Re: I need to get a new speedo cluster for my 94 si does it have to be from a 94 or can it be someth
I want a white faced si or type r gauge and found one for a 96
Old Oct 30, 2006 | 08:30 PM
qat727's Avatar
Just wondering here... do you NEED a new cluster as in your current one is trashed, or do you WANT a different cluster, as in you don't like your current one?
Either way, any 92-95 Si or EX ought to work, the only thing that is different is some have ABS lights, and some are auto (only difference to the best of my knowledge)
If you are going with the JDM white faced gauges, better study up on your metric conversions so you can figure out how fast you're going with that pimp *** Kph speedo.
There are plenty of writeups on how to do a teg gauge swap into an EG.
here's one:
https://honda-tech.com/zerothread?id=1053318
here's a really great FAQ thread:
and from what my research has indicated, I don't see a reason why certain parts of a 92-95 VX cluster couldn't be used in an Si or EX cluster if you need to exchange them.
Old Nov 1, 2006 | 12:57 PM
I have a jdm type r cluster and the speedo stopped working so im gonna replace it.
Old Nov 1, 2006 | 01:05 PM
Old Nov 1, 2006 | 02:39 PM
Relic1's Avatar
if you have a JDM R cluster in there then you have done a cluster conversion all ready.
The ITR cluster from 98+ is swapable with any teg cluster 96+
If you're refering to the civic R cluster... I don't know.
From the factory the 94SI uses the same cluster wiring as any other 92-95 civic.
BTW I'd be interested in the R cluster with the bad speedo. hit me up on IM if you're interested in getting rid of it.
Old Nov 1, 2006 | 04:21 PM
Default Re: (Relic1)
yeah its a civic type r cluster, besides the speedo not working, my biggest problem is it doesn't say type r or anything on it.
BadKid
Jun 6, 2008 11:25 PM
gotnos2
Northwest (Sales)
Jan 29, 2007 12:48 PM
JohnnyEF
Jul 16, 2002 02:54 PM
hipnotize
Jun 6, 2002 02:06 PM
