ITR Sway bar hitting RSR exhaust on ek!
Old Oct 30, 2006 | 06:16 PM
crexer's Avatar
Default ITR Sway bar hitting RSR exhaust on ek!
Hey i just installed a 22mm ITR rear sway bar on my 97 ek with an RSR ex mag axle back. I used the asr brace kit and the sway bar is sitting on the rsr's exhaust pipe. I also have function7 adjustable endlinks and have tried adjusting all the way up and down but the bar still sits right on the exhaust. What do you all suggest doing to solve this? The rsr's fitament with the bumper is so tight I dont think a shorter exhaust hanger would fix anything...I love the way it sounds so I dont want to change to something else. Let me know some of your ideas!
Old Oct 30, 2006 | 06:29 PM
BlueIntegraBoy's Avatar
Default Re: ITR Sway bar hitting RSR exhaust on ek! (crexer)
Cut the section of the exhaust piping hitting the sway bar and weld in a more bent piece.
Old Oct 30, 2006 | 06:56 PM
M12's Avatar
M12
Im running into the same problem on my EM1.
I cant get shorter hangers cause then the exhaust will hit my OEM rear lip.
I have maybe 2-3mm between the exhaust tip and my rear lip. My sway right now is a couple mm above the exhaust and when cold, it will come in contact with the rear sway.
I moved the rear sway as low as possible but sometimes, it still touches the exhaust.
Old Oct 30, 2006 | 09:20 PM
crexer's Avatar
Default Re: ITR Sway bar hitting RSR exhaust on ek! (M12)
Think the sway bar being upside down has anything to do with all this?
Modified by crexer at 1:37 AM 10/31/2006
Old Oct 30, 2006 | 09:45 PM
Yes, if it's upside down, it will hit. The sway bar should go down from the subframe and up and over the LCA.
Old Oct 30, 2006 | 09:50 PM
crexer's Avatar
Default Re: ITR Sway bar hitting RSR exhaust on ek! (BlueIntegraBoy)
yeah i was being sarcastic, haha thanks for your help man, i got it figured now!
stilzx61
Honda S2000
10
Sep 3, 2008 10:38 PM
DSMkiller
Apr 7, 2008 01:12 PM
GripFactoR
May 19, 2003 05:12 PM
civicmatt
Oct 17, 2002 05:43 PM
porch
Oct 30, 2001 06:16 PM
