Water Leak. Water Behind Driver Seat On Floor 92 Civic Hatch
There is water appearing on the floor behind the drivers seat during hard rains. I have no idea where this might be coming from. I looked at it and cant seem to see.
Anyone have any suggestions or tips on locating the problem?
Thanks
CRX Forum
Thanks
CRX Forum
check the rear tail lights water can leak in there. If you car has a sun roof there are drains that can clog and let water in the last place to check would be a leaking seal around the rear window. Just remember water can come in at the right rear hatch and end up in the left rear foot well you just never know where its going to run once its in the car
in my EG, i got a little leak too. Check your floor where the spare tire sits, some how i got a little hole there and sometimes some moisture gets in there so give it a check if not hey i tried.
Trevor
Trevor
The way I found the leak I thought was impossibe to find was by taking out the carpet and having someone run some water with the water hose until I saw where the leak came from.
SonicRacing
Aug 28, 2007 08:11 AM
