headlight adjustment
Old May 6, 2002 | 11:57 AM
fiebru1119's Avatar
Default headlight adjustment
i noticed my right headlight is a little low so i decided to adjust it. when i went to do it, i noticed that the "bubble" inside the headlight is pointing down. im not talking about the entire plastic clear housing, im talking about the glass bubble inside the low beam side of the headlight. i also noticed that the whole rubber casing where the bulb goes into is loose and this is why the light is off alignment. how can i tighten this? BTW, the left headlight is nice and tight, so im guessing there is something loose.. anybody? thanks
Old May 6, 2002 | 02:23 PM
SIK IN DA HED's Avatar
New User
Default Re: headlight adjustment (fiebru1119)
that bubble is supposed to be a tool in centering the headlight. it should be in the middle of the measurement bar. that rubber seal shouldnt give you trouble with your headlight adjustment. its there to hold the bulb in place.
Old May 6, 2002 | 03:34 PM
vteg's Avatar
New User
The bubble is a level. If you are on level ground and the headlights are adjusted correctly then the bubble should be in the middle. As said earlier, the plastic part should not be loose.
Old May 6, 2002 | 08:08 PM
fiebru1119's Avatar
Default Re: headlight adjustment (vteg)
damn i think my headlight is broken the other one is perfect, the rubber is real stiff and wont move easily, the other headlight moves around like nothing.. do i have to get a whole new headlight?
Old May 6, 2002 | 08:40 PM
vteg's Avatar
New User
Can you super glue it or something. You are talking about the black plastic ring that the bulb screws into right. New headlight assemblies are not cheap.
Old May 6, 2002 | 08:42 PM
dLo GSR-stolen-now-WRX's Avatar
From: kyoto sangyo daigaku, kyoto, japan, sometimes bay area CA
i just tried to adujust mine. exacept my haynes manual only showe done adjustment point, yet there are two, one for vertical and one for horizontal. i tried moving the point it showed me and it didn't go up or down; nor did I notice it go left or right. What's the real, detailed way? my left headlight is too low. i really need to trash this universal civic/integra/crv haynes manual and get a helm's.
Old May 6, 2002 | 10:09 PM
PaChiLa Leader's Avatar
Default Re: headlight adjustment (dLo GSR)
trash this universal civic/integra/crv haynes manual and get a helm's.[/QUOTE]
Old May 7, 2002 | 12:21 AM
vteg's Avatar
New User
For 99 your adjustment for the vertical is a nut. I think it is like a 8mm or 10mm socket. Turn that. You will know it. It looks like a washer with holes and a bolt in the middle.
Old May 7, 2002 | 12:23 AM
New User
there are 4 nuts and bolts that hold the headligsht in place. loosen all four... center the headlight til the bubble is in the middle. position the headlight when its centered and tighten all the bolts.
Old May 9, 2002 | 06:03 AM
fiebru1119's Avatar
Default Re: headlight adjustment (dlplayboy)
alright guys, i did exactly what you guys told me for the left light and it is centered perfect.. however, the right side is still low,and that thing is still loose.. im actually thinking of supergluing it!!
thanks for the responses
[Modified by fiebru1119, 3:03 PM 5/9/2002]
brian2613
Jan 24, 2018 02:20 AM
04TYPEsaggin
May 12, 2008 04:11 PM
patrickstar
Nov 12, 2007 05:35 AM
94ls
Jan 28, 2005 07:30 AM
