Car Starts then Immediatly Cuts off
My 94' Civic DX hatch with D15B7 motor will sometimes immediatly cut back off after I crank it up. It has cut off ONCE after I drove about 20 yards, other than that it is always right when I crank it up. Once I restart the car it doesn't have any issues until I shut it down and get back in later.
This does not happen every time, I would say perhaps 30 - 40% of the time.
Any ideas? So far I tried cleaning out the throttle body with some Valvoline Synthetic TB cleaner spray.
Something similar happened to my brothers car. Turned out he had a small tear in his fuel line, causing low fuel pressure.
Check your fuel lines and listen to see if you hear your fuel pump priming.
oneslowcivic
Sep 19, 2003 08:02 PM
