somthing..pops when letting off the throttle
Old Oct 30, 2006 | 06:15 AM
DTS's Avatar
DTS
Default somthing..pops when letting off the throttle
Having an odd noise that happens every once and a while but not all the time,
when starting off in 1st and letting off the throttle around 4000rpm i get a small pop sound from the front drivers side wheel and the same in 2nd..
this only happens some times and is not evident in other gears..
im thinking the lower ball joint of the control arm bushing maybe?
its not mounts since there avids..
Old Oct 30, 2006 | 06:49 AM
eg-owns you's Avatar
avid mounts? them suck nothing ever comes good from avid everything i have bought has been ****
but it is prob your balljoint or could be your axle have you check both of them yet becuase you can tell right away when both of them are bad get it jaked up in the air and push on your tire and what not rattle it around you will get a better understanding of whats wrong if it is somthing with the joints
Old Oct 30, 2006 | 07:00 AM
DTS's Avatar
DTS
Default Re: (eg-owns you)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg-owns you &raquo;</TD></TR><TR><TD CLASS="quote">avid mounts? them suck nothing ever comes good from avid everything i have bought has been ****
but it is prob your balljoint or could be your axle have you check both of them yet becuase you can tell right away when both of them are bad get it jaked up in the air and push on your tire and what not rattle it around you will get a better understanding of whats wrong if it is somthing with the joints</TD></TR></TABLE>
ya i agree with you my avid axles **** the bed in 6 months
thanks for the tip
Old Oct 30, 2006 | 12:02 PM
dognutz's Avatar
Default Re: (DTS)
I Have the same problem and have not had the time to look in to it. I was thinking it was the axle. I replaced my lower ball joints with moog's, so I'm leaning towards the shiaty rebuilt alxe I put in. It lasted a year though
Old Oct 30, 2006 | 07:20 PM
DTS's Avatar
DTS
Default Re: (dognutz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dognutz &raquo;</TD></TR><TR><TD CLASS="quote">I Have the same problem and have not had the time to look in to it. I was thinking it was the axle. I replaced my lower ball joints with moog's, so I'm leaning towards the shiaty rebuilt alxe I put in. It lasted a year though </TD></TR></TABLE>
i dont think thats the problem, the problem was evident with my old axles and the new ones (new ones have 200 km)
im leaning towards lower ball joint or tie rod ends...
changing them both tomorrow and well see whats up
Old Oct 31, 2006 | 02:38 AM
92ehatch's Avatar
Default Re: (DTS)
had that happen in my accord, i never found it. but the guy i sold it to did.
it was balljoint
Old Oct 31, 2006 | 02:19 PM
EJgsr's Avatar
Default Re: (92ehatch)
ball joint or axle.
diva_3181377
Sep 14, 2018 08:27 AM
HondaGuy951
17
Jan 8, 2009 06:31 PM
B16A Hatchback
Aug 29, 2008 04:19 PM
faSHOwidIT
12
Feb 12, 2007 09:40 PM
Lo-Buck EF
12
Nov 26, 2002 07:29 PM
