GSR Gears and Diff
i just found out that my 00 ITR has gsr gears and differential... will this make my car considerably slower?.. i was asking this on the other post before it got locked so hopefully i can get an answer
Yes the gear ratio stack is longer, Final drive ratio is the same as far as USDM models are concerned, and you don't have an LSD if you are running the GSR differential.
