Car sputtering? Wrong type of GAS, or fuel filter?
Old Oct 29, 2006 | 12:03 PM
turboeg831's Avatar
Default Car sputtering? Wrong type of GAS, or fuel filter?
Here's my problem. i have a poor man's type r, and my car started sputtering all through the powerband. the past 3-4 days ive been using RACETRAC 93octane gas...is that the problem? or is it the fuel filter which is long overdue for a change...? thanks.
Old Oct 29, 2006 | 12:24 PM
0618turbocivic's Avatar
Default Re: Car sputtering? Wrong type of GAS, or fuel filter? (turboeg831)
timing?
Old Oct 29, 2006 | 12:35 PM
JDMFantasy2k's Avatar
ignition problem possibly need more info
Old Oct 29, 2006 | 12:42 PM
turboeg831's Avatar
as i go through gears 1-5 the car would run normally but seem to sputter a little and bog down...kind of hard to explain.
Old Oct 29, 2006 | 01:44 PM
baozer's Avatar
sparkplugs, sparkplug wire, distributor cap and rotor those might be the culprit if not anything else
EG2Driver's Avatar
Default Re: (turboeg831)
mine used to bogg at idle. Turns out i used 87 gas instead of 91. I got a B16. You might have had a bad batch of gas.
Old Oct 29, 2006 | 01:50 PM
turboeg831's Avatar
thanks for the great replies...ill have to see whatsup now.
Old Oct 29, 2006 | 01:58 PM
sohcvtec1995's Avatar
Racetrack gas is horrible. my friends mom's mustang would throw a code if she ever put racetrack gas...
Old Oct 29, 2006 | 02:35 PM
Mhollaek9's Avatar
its an ignition problem i had the same problem prolly a misfire with the sparks
Old Oct 29, 2006 | 04:40 PM
turboeg831's Avatar
So, new sparks and wires will do the job eh??
Old Oct 30, 2006 | 05:50 AM
turboeg831's Avatar
what do you guys think is wrong with my ignition??? should i check the plugs and wires??? its bogging down still...
Old Oct 30, 2006 | 07:38 AM
JDM_EK_wanabe's Avatar
my car had pretty much the same problem, but i had a bad conection on the map sensor, just took it off and scraped the terminals, look at your plug and see if is coroded at all
Old Oct 30, 2006 | 08:10 AM
Syndacate's Avatar
Default Re: (sohcvtec1995)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohcvtec1995 &raquo;</TD></TR><TR><TD CLASS="quote">Racetrack gas is horrible. my friends mom's mustang would throw a code if she ever put racetrack gas...</TD></TR></TABLE>
lmao
at OP:
It's always possible you got a bad batch of gas...though 89 octane should be sufficient...might even be able to use 87...what's ur comp?
Old Oct 30, 2006 | 08:33 AM
DaveSi677's Avatar
Default Re: (Syndacate)
he said he has a poor mans type-r meaning he needs to run 91 octane.
Old Oct 31, 2006 | 10:55 AM
turboeg831's Avatar
Default Re: (DaveSi677)
found out after i put in brand new sparks and wires that it's the map sensor. it's throwing up code 3. what to do now?!?!?!
Old Oct 31, 2006 | 04:16 PM
test the wiring, then test the sensor, dir
gsxremep3
Aug 29, 2013 08:30 PM
oj5joker
Jun 26, 2010 12:22 PM
jb0705
Mar 24, 2008 07:42 PM
4inspeed
Jan 18, 2004 12:20 AM
chiefvtec
Mar 28, 2003 11:40 AM
