Suspension & Brakes Theory, alignment, spring rates....
Ej1 front lower control arm question?
Old Oct 29, 2006 | 07:05 AM
m00nr0ck Si's Avatar
Default Ej1 front lower control arm question?
Well Im running omni coilovers and I noticed that the front lower control arm bottoms out on a stop mounted to the frame...when I look under the car from the front I notice that the control arm is only 1"--1.5" away from it ....can you cut these off or remove them...Im not all that low and my control arms bottom out very easily....
702SI
Suspension & Brakes
May 12, 2017 07:00 AM
SikofFalln
Mar 26, 2002 02:08 PM
