fuse box under dash and alarm problem
each of those slots are different. one has power always. one has power when the lights are on.. and etc.... you should use a test light to see which is which you could tap the wires together if thats what you need.. i remember i had to when i had afew different things
are the 5 one-pin plugs on the fuse box all the same because i just recently installed the pwjdm 96-98 foglights and i had to plug in the the 2 one-pin connector to the fuse box i had to use the 2 connectors on the left but there was a wire that was in the 2nd connector from the left that i unplugged and it was for my alarm..just wondering if i could put that wire in a different connector or should i tap it in to the same wire?..that wire i took off makes my exterior and interior lights flah when the alarm is engaged/disengaged thanks in advance
Modified by jdmjunkieXL at 1:49 AM 10/29/2006
SiRCiviC94
Sep 15, 2012 04:56 PM
nerdish
Aug 9, 2001 03:13 PM
