draining and flushing coolant out of block!?
Old Oct 28, 2006 | 11:52 PM
93(Civic)EG6's Avatar
Default draining and flushing coolant out of block!?
Anyone know where the drain plugs are for the coolant located on a b16?? It is somewhere near the oil filter?
Old Oct 29, 2006 | 01:13 AM
anothersickhatch's Avatar
Default Re: draining and flushing coolant out of block!? (93(Civic)EG6)
the drain plug to release coolant is on the front of the block underneath the motor stamp. it should be right below and to the right of the "b16a" stamp.
i think its a 19mm bolt with a washer on it.
Old Oct 29, 2006 | 01:44 AM
Eran's Avatar
HT White Ops
Default Re: draining and flushing coolant out of block!? (anothersickhatch)
My coolant drains are behind my exhaust manifold on my ls
Old Oct 29, 2006 | 02:13 AM
nello a.'s Avatar
not necessary. the radiator draincock is the lowest point in the system. drain -fill with distilled water-run heat-drain-fill with honda premix(add some redline if you are inclined) or 50% prestone(or something brand name) and 50% distilled water.
Old Oct 29, 2006 | 07:40 AM
Default Re: (nello a.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nello a. &raquo;</TD></TR><TR><TD CLASS="quote">not necessary. the radiator draincock is the lowest point in the system. drain -fill with distilled water-run heat-drain-fill with honda premix(add some redline if you are inclined) or 50% prestone(or something brand name) and 50% distilled water.</TD></TR></TABLE>
Yes it is cause i am changing my type of coolant !!! Need to completely flush it!!!
Thanks every1 for the help!
whiteGSR
Jul 26, 2022 03:06 PM
Rvu
Jan 29, 2010 08:15 AM
mikestypeRR
Nov 17, 2005 01:11 PM
dman81
Mar 7, 2005 10:19 AM
