Need Some Advice on Brakes
Old Oct 28, 2006 | 09:55 PM
RedSiHatch's Avatar
Default Need Some Advice on Brakes
Hey guys, i need some advice on my brakes. My 93 Si hatch needs some more braking power. Its got an LS motor on a 75 shot. After two runs my brakes start to fade and the car has trouble stopping. It has front and rear discs, but I need something better. I wanted to get a Powerslot big brake rotor kit, but i have 15" slipstreams and i was told by one of my friends who has them, that you need 16's in order for them to fit. I was wondering if i could get away with integra brakes, cross drilled and slotted rotors, and ebc pads? I am open to any suggestions, please help!
Old Oct 28, 2006 | 10:07 PM
John M's Avatar
Default Re: Need Some Advice on Brakes (RedSiHatch)
Old Oct 28, 2006 | 10:20 PM
chrisw85's Avatar
slotted and drilled rotors have less metal, so think of it as a weaker heatsink than a solid rotors.
so, get yourself some blanks (brembo works, but so does the less expensive autozone duralasts that many nasa/scca racers use), hawk hps pads, bleed/flush fresh fluid and you'll have some dime-stoppin' brakes. maybe freshen your brake lines with new ones (ss braid is up to you if you want to deal with the risks) and freshen up the master cylinder if its old.
Old Oct 28, 2006 | 11:32 PM
sol2hatch's Avatar
Default Re: Need Some Advice on Brakes (Teal-EJ1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Teal-EJ1 &raquo;</TD></TR><TR><TD CLASS="quote"> </TD></TR></TABLE>
are you kidding me? Please dont post stuff like this. That is a retarded way to get your post count up. A post count doesnt meant ****. How much you help and know will gain you respect. I can think of several people that have a **** ton of post, but I wouldnt take a word of advice from.
/rant
OP, get blanks and good pads as stated before. Dont waste your money on a big brake kit.
Old Oct 29, 2006 | 09:41 PM
RedSiHatch's Avatar
Default Re: (chrisw85)
Instead of getting hawk hps pads, should i get hawk hp plus pads?
Old Oct 29, 2006 | 09:47 PM
DaveSi677's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chrisw85 &raquo;</TD></TR><TR><TD CLASS="quote">slotted and drilled rotors have less metal, so think of it as a weaker heatsink than a solid rotors.
so, get yourself some blanks (brembo works, but so does the less expensive autozone duralasts that many nasa/scca racers use), hawk hps pads, bleed/flush fresh fluid and you'll have some dime-stoppin' brakes. maybe freshen your brake lines with new ones (ss braid is up to you if you want to deal with the risks) and freshen up the master cylinder if its old.</TD></TR></TABLE>
Agreed
Old Oct 29, 2006 | 11:21 PM
nello a.'s Avatar
carbotech pads and cheap rotors.
Old Oct 30, 2006 | 07:50 PM
RedSiHatch's Avatar
So I just get new rotors and a good set of pads? So I shouldn't upgrade to integra GS-R brakes?
Old Oct 30, 2006 | 08:11 PM
sol2hatch's Avatar
Default Re: (RedSiHatch)
try blanks, good pads, and changing out your brake fluid first, and then you can decide if you need bigger brakes after that
Old Oct 30, 2006 | 08:15 PM
yoej8's Avatar
i have pbr axxiss ultimates w/ brembo blanks w/ with good sticky tires. but you could always wait on the tires.
Tenzo
Suspension & Brakes
May 24, 2012 01:04 AM
kimokalihi
22
Dec 9, 2008 05:29 PM
Dfish1
Apr 15, 2004 07:37 AM
Blindstuff
24
Jan 5, 2004 06:29 AM
93SSPHatch
May 15, 2002 05:17 AM
