Aluminized steel, can it be flux welded?
Old Oct 28, 2006 | 12:31 PM
CBURKE's Avatar
Default Aluminized steel, can it be flux welded?
Just wondering if this is possible. And is this like miled steel?
Old Oct 28, 2006 | 12:56 PM
NJIN BUILDR's Avatar
Default Re: Aluminized steel, can it be flux welded? (CBURKE)
Yes,its just coated mild steel.I sand or grind the coating off where I 'm going to weld.
Old Oct 28, 2006 | 01:01 PM
CBURKE's Avatar
What does the coateing do?
Old Oct 28, 2006 | 01:18 PM
ManBearPig4silly's Avatar
Prevents rust.
Old Oct 28, 2006 | 01:28 PM
CBURKE's Avatar
Well damn, I could have been getting this stuff all along!!!
Thanks for the info.
Old Oct 29, 2006 | 03:50 PM
cua0's Avatar
you don't even have to grind the coating off, you can weld through it, but you will inhale a lot more noxious gasses if you do it that way.
zinc chills are fun!
Old Oct 29, 2006 | 04:37 PM
C_H_A_D's Avatar
Default Re: (cua0)
What is Aluminized steel? is it like galvanized?
Old Oct 29, 2006 | 04:43 PM
RC000E's Avatar
Default Re: (cua0)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cua0 &raquo;</TD></TR><TR><TD CLASS="quote">zinc chills are fun! </TD></TR></TABLE>
Learned this the hard way....woke up in the middle of the night sweatin feelin like dogs ***
Old Oct 30, 2006 | 05:48 AM
CBURKE's Avatar
Wow I did not know that about zinc chills. sucks!!!
Old Oct 30, 2006 | 07:06 AM
PrecisionH23a's Avatar
Default Re: (CBURKE)
Yep, make sure you grind all of the coating away otherwise you can get sick.
HT Chaplain
Welding / Fabrication
Jan 25, 2008 06:23 PM
silentdaredevil2
Jul 24, 2006 10:41 AM
ctownintegra
Feb 26, 2006 12:59 PM
parasonic
22
Dec 11, 2004 09:15 AM
spoonhatchblack
14
Sep 10, 2004 08:53 PM
