B16 prices with or without mounts
Old May 6, 2002 | 07:56 AM
Kasper.'s Avatar
Default B16 prices with or without mounts
Alright I was almost set on diong a ZC swap since I wanted to do some auto crossing this summer plus I wanted to get a new paint job and have a pretty rex.
Well Ive come to the conclusion that I dont care about empressing anyone anymore and that I want power...so im leaving my car completely primered and stock height for now......So I can save up enough for a b16.
Ive read all about it yes this and that....and Ive looked up alot of price quotes...talked to larry at Importautosalvadge and he gave me a descent quote....for 2400....for everything. But I found Honda MOtors online site, and it was only 1,250 for full chance over...they seem reliable anyone go through them??
PS:It says the b16 sir1 comes with oem mounts...that wont work in my dx will it??? Ill have to get hasport mounts right??? cause those are 600 on there site..just need to know what to be prepared for
Old May 6, 2002 | 08:17 AM
slowpokesi's Avatar
Default Re: B16 prices with or without mounts (Kasper 1)
if you had already read all about it then you would know that you need a mount kit and the mounts that came with it wouldnt work.
MOUNT KITS:
hassport 400-600<-billet aluminum
place racing 400
hcp 400
you will need a shift linkage either from hassport, place racing, hcp unless you know a welder that can modify your stock linkages.
you will need a cable tranny swap.
honda motors oline comes with
engine
tranny
mounts <-- dont need
linkages <-- cant use unless you modify them
ecu
wiring harness for 1250
if the other swap was 2400 that was probably the delsol b16a wich has a hydraulic tranny.
Old May 6, 2002 | 08:26 AM
Kasper.'s Avatar
Default Re: B16 prices with or without mounts (slowpokesi)
Damn man the linkage wont work from the honda motors change over??? should I just buy like the Tranny, Ecu, Harness and Long block from like JDM hondaparts and order the moutns and linkage from hasport sep. then?
Old May 6, 2002 | 08:28 AM
Kasper.'s Avatar
Wait ....lol I forgot ill still need the axles and half shafts....
Old May 6, 2002 | 08:54 AM
turbo_ef9's Avatar
you shoulda hit me up like 3 weeks ago.. i had a complete swap.. mounts, axles, linkages everything.. i still got half shaft and axles.. axles are brand new.. just bought.. 92 gsr.. 225 shipped.. the half shaft will be 75 shipped..
Old May 6, 2002 | 09:58 AM
ricodemus's Avatar
I got my swap @ hondamotorsonline.com for 2150 shipped (cut me an ok deal on the mounts), which was the stuff they advertise + lsd + HASPort mounts. I was a little dissappointed in the fact that my t/b had a busted vaccuum port and the tranny was missing the clutch cable bracket. these are little things I understand, that's why I'm not pissed at all (**** happens, I didnt want to wait for him to send me new parts [time]). Also, the vtec isnt working and all signs point to the ecu. I bought another ecu, so I will see if I can verify this. If it really is the ecu, then I will call steve @ hmo and complain, but I'm not doin that until I'm sure. We'll see how he handles it from there, I'll know later this week when I get the new ecu. hth
Old May 6, 2002 | 10:16 AM
slowpokesi's Avatar
Default Re: B16 prices with or without mounts (ricodemus)
i havent got my motor yet, but something tells me this motor is going to be in mint tiptop shape.
its good to have hookups
Old May 6, 2002 | 11:14 AM
Kasper.'s Avatar
So are you guys saying honda motors is reliable?? i mean christ vtec doesnt work>??? was this somthing you screwed up on the pin codes in the ECU...or are you saying you got a bad eCU???
What kinda tranny are you guys running, I was just going to get the Y1...cause Ill doing a ton of highway driving with this motor.....
Old May 6, 2002 | 11:19 AM
EP3_05's Avatar
I got my swap from hondamotorsonline. It came in great shape although the crank pulley and alternator puley was chipped...could of happened in shipping so I didn't complain. everything else was perfect and I used the axles that came with the swap as cores for brand new ones.
7rrivera7
Mar 13, 2014 10:40 AM
svacca1
Nov 16, 2007 08:49 PM
folta2169
Dec 23, 2004 12:03 PM
