gas question
Old Oct 28, 2006 | 10:10 AM
ic89's Avatar
Default gas question
i am using regular gas 87 octane, if i go up to 89 octane gas special will it harm my car and if i degrade back to regular is that bad also?
help!!!
Old Oct 28, 2006 | 10:18 AM
Eran's Avatar
HT White Ops
What motor are you running?
Should you use 89? Is there a reason to?
Old Oct 28, 2006 | 10:19 AM
ic89's Avatar
Default Re: (Eran)
i have a d15b7, some people reccomended me 2 use it once in awhile cause it burns cleaner
Old Oct 28, 2006 | 10:24 AM
Eran's Avatar
HT White Ops
Default Re: (ic89)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ic89 &raquo;</TD></TR><TR><TD CLASS="quote">i have a d15b7, some people reccomended me 2 use it once in awhile cause it burns cleaner</TD></TR></TABLE>
It does burn cleaner, but is not necessary. Just put 1/3 of a can of seafom in your tank every couple of months. Way cheaper than filling up with plus.
Old Oct 28, 2006 | 10:25 AM
f20bej1's Avatar
higher octane runs cleaner less residue on valve and less build up on pistons go only super
Old Oct 28, 2006 | 01:07 PM
ic89's Avatar
Default Re: (f20b eg)
if i go super and i want to degrade back to regular next time i refill, can i do so without it harming my engine
Old Oct 28, 2006 | 04:10 PM
stock_honda_coupe's Avatar
Default Re: (ic89)
yes. I wouldn't worry about it to much. The rating only stands for the amount of octain in the fuel. It does burn cleaner but not enough to really make a difference. If your engine doesn't ping and you don't drive like grandma you should be fine.
McFlurry
Dec 25, 2009 12:52 PM
djdownfawl
Honda Civic (2001 - 2005)
13
Mar 23, 2008 07:57 PM
hmongboyLS
Oct 7, 2004 09:14 PM
4DRmafia
Sep 14, 2004 05:14 PM
Darkane
Aug 3, 2004 12:44 PM
