Hasport axles slinging grease
Old Oct 27, 2006 | 09:59 PM
spoonracer84eg's Avatar
Default Hasport axles slinging grease
I just installed these axles yesterday in my 93 hatch. I started having problems with my car boging at vtec so im looking under my hood and see grease that appears to be coming from my passenger side BRAND NEW hasport axle. Has anyone else had failure from there axles like this? I am pissed because I now have 2 major problems with my car and its the only vehicle I have POS
Old Oct 27, 2006 | 10:20 PM
Default Re: Hasport axles slinging grease (spoonracer84eg)
Anyone had their axles sling grease before?
Old Oct 27, 2006 | 10:55 PM
bump
Old Oct 28, 2006 | 12:42 AM
chrisw85's Avatar
if the boot clamp wasnt tight enough, yes.
Old Oct 28, 2006 | 02:33 AM
rmcdaniels's Avatar
Default Re: (chrisw85)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chrisw85 &raquo;</TD></TR><TR><TD CLASS="quote">if the boot clamp wasnt tight enough, yes.</TD></TR></TABLE>
x2
Old Oct 28, 2006 | 03:31 AM
6SPD_EK's Avatar
or you have a torn boot already
Old Oct 28, 2006 | 11:00 AM
Default Re: (_adirondackR_)
Well it was dark last night so all I could really see was the fact that there was grease everywhere. Going to check it in a little bit.
Old Oct 28, 2006 | 11:10 AM
Jimmy's Avatar
Global Moderator
I'd be more than willing to bet when you installed the axle you got a ''minor'' tear or rip in the boot and TADA.. Grease everywhere, but hopefully i'm wrong and they'll replace your axle..
I hate bad luck.
Old Oct 28, 2006 | 11:17 AM
Default Re: (Jimmy)
Ill look for a tear. Fortunately its the inner boot. If I find one ill put some rtv on it or maybe some double bubble.
Old Oct 28, 2006 | 11:20 AM
Jimmy's Avatar
Global Moderator
Default Re: (spoonracer84eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoonracer84eg &raquo;</TD></TR><TR><TD CLASS="quote">Ill look for a tear. Fortunately its the inner boot. If I find one ill put some rtv on it or maybe some double bubble.</TD></TR></TABLE>
Won't work.. Well it will, but it's only temporary.. Get that axle outta there.. Grease is gonna be everywhere.
Old Oct 28, 2006 | 11:24 AM
John M's Avatar
Default Re: (Jimmy)
hm a torn boot shouldnt cause your car to bog under vtec ................
Old Oct 28, 2006 | 11:26 AM
93(Civic)EG6's Avatar
if u want to keep the axles and you do have a tear just repace the rubber part for like $20
Old Oct 28, 2006 | 11:36 AM
Default Re: (Teal-EJ1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Teal-EJ1 &raquo;</TD></TR><TR><TD CLASS="quote">hm a torn boot shouldnt cause your car to bog under vtec ................</TD></TR></TABLE>
lol The story with that is I replaced the axles, tranny fluid, and motor oil. Noticed the next day that my car is running like **** and when vtec kicks in it completely bogs out and wont excelerate anymore. Looking under the hood I noticed the grease. So I am currently trying to work 2 major problems on my daily driver
Old Oct 28, 2006 | 11:58 AM
Well I found a hole. I must have done it putting the axle in. It is a pretty small hole but a lot of grease is coming out lol
slikz714
May 22, 2007 02:30 AM
canadianSIR-G
Jan 31, 2007 10:14 AM
slkleltlclh
Nov 8, 2006 09:36 PM
JFG Kevin
Mar 16, 2006 01:38 PM
b18bfreak
Aug 2, 2004 10:05 AM
