Deciding on a welder, need some input
Old Oct 27, 2006 | 07:37 PM
page916's Avatar
Default Deciding on a welder, need some input
Hello all,
time to upgrade from my little lincoln weldpak 100. If you guys had a single choice between getting a millermatic 210 (mig) of syncrowave 200 (tig) which would you go with. I'm mostly a hobbyist at best. I mostly do some exhaust welding (not fabing headers), will get into some stainless intercooler piping and will be making a welding table (box steel with either 1/4 or 3/8 table top). As for mig welder I believe it's more forgiving; i.e. get away with more of a gap between the two objects, pipes, etc. you are trying to weld. For the tig it's more of a persision welder?
Any input would be great..
Thanks,
Old Oct 28, 2006 | 01:07 AM
Lamchop0000's Avatar
Default Re: Deciding on a welder, need some input (page916)
2 different welding process machines
but Tig can do anything Mig can do. but slower, more precise, cleaner but of course the operator needs to be on par also.
Old Oct 28, 2006 | 07:09 AM
LostAndFound's Avatar
you interested in selling your weldpak, i just bought a mig but if its reasonable I can mabye get that instead. Located in Northern NJ.
Old Oct 31, 2006 | 11:19 AM
page916's Avatar
Default Re: (LostAndFound)
will probably hold onto my weldpak for now. Not sure as to when I will be getting the welder.
Old Oct 31, 2006 | 01:11 PM
Howitt's Avatar
Default Re: (page916)
if the work is only for your self I would say get the tig, you can weld a wider range of metals w/o switching gas and its for your self you dont mind if its take 4x times longer than migging it. Plus it will look better
89efhatchy
Welding / Fabrication
15
Apr 29, 2012 03:43 PM
Gr8DC2R
Nov 11, 2007 06:45 PM
page916
Oct 29, 2006 11:41 AM
TurboSI56
10
Jun 8, 2006 04:56 PM
SinSeven
Mar 12, 2003 10:33 AM
