ECU Wiring Pins?
Old Oct 27, 2006 | 06:37 PM
ZenDynasty's Avatar
Default ECU Wiring Pins?
Where do you get the ECU pins I need them to wire up the Vtec and knock on GSR EG swap. I also need the pins to the engine harness. Can you buy these at a store or only through honda?
PM me need to know asap thanks!
Old Oct 28, 2006 | 11:30 AM
Timberland237's Avatar
Default Re: ECU Wiring Pins? (ZenDynasty)
honda must have them i'm also wondering i'm doing the same swap so BUMP
Old Oct 28, 2006 | 11:36 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Your best bet is to probably just find a trashed or hacked harness or just pull a random harness from a car in a junk yard, and then use the pins on there. Just cut off several inches of wire with the pin on the end and solder it to the end of your main length of wire. Always cover the soldered joint with heat-shrink tubing.
Coopa B18c5
Dec 14, 2012 06:13 AM
AccordVT
Jan 22, 2010 07:46 AM
90Rexx
Mar 26, 2009 12:30 PM
philkehn
May 28, 2006 07:44 AM
Prevail
Apr 17, 2004 08:06 PM
