Vtec wiring
Old Oct 27, 2006 | 02:16 PM
Mr. Roboto's Avatar
Default Vtec wiring
whats up everyone, I got a 92 civic cx (d15b non Vtec) and i'm swapping in a D15b8 (Vtec). The engine came with a cut wirng harness, so I called around and asked about what I should do and was told that I would need to wire up Vtec through my stock motor wire harness. I've never done that before so could you guys give me some assistance, Thanks in advance.
Old Oct 27, 2006 | 02:44 PM
mc's Avatar
mc
Default Re: Vtec wiring (Mr. Roboto)
take the plugs off the hacked up harness for the vtec solenoid and vtec pressure switch and run them to the passenger side shock tower harness. Connect the Ora/Wht to the VTEC Solenoid and the ORA/BLU to the VTEC Pressure Switch. The black one should be ground. Since you have a 92 the rest of the wiring to the ecu should be there.
Old Oct 27, 2006 | 02:57 PM
baphomet's Avatar
Here you go. This too.
Just searched google.
Old Oct 27, 2006 | 03:00 PM
SOHCejcivic's Avatar
Default Re: Vtec wiring (baphomet)
check the stickies....there's one with a shitload of how-tos
Old Oct 27, 2006 | 03:13 PM
Mr. Roboto's Avatar
just double checkin I would be running the wires on a non Vtec wiring harness so does the posts above still apply?
Modified by Mr. Roboto at 6:02 PM 10/27/2006
Old Oct 27, 2006 | 03:53 PM
mc's Avatar
mc
yes, that's how I have mine setup w/ a non-vtec harness. You just need the actual plugs off a vtec harness
Old Oct 27, 2006 | 05:03 PM
Mr. Roboto's Avatar
thanks alot
Einhander276
Aug 2, 2011 05:47 PM
xJDMCx
20
May 1, 2011 08:57 AM
AIWFCIATR
Jul 23, 2004 12:11 AM
quicksol95
Mar 19, 2004 01:50 PM
bigblock-EG
Mar 26, 2002 08:36 AM
