anyone using COMP CAMS???
Old Oct 27, 2006 | 02:03 PM
92integraVTECgsr's Avatar
Default anyone using COMP CAMS???
i got some COMP Cams in a trade. They are brand new. I am going to put them in my JDM B16XSi.
just wanted to know who is using them and would like some opinions about them and what kind of valvetrain u are running using with them.
Preferably B16, B18c1, B18c5 people running COMP Cams.
are they good, bad, what???
Old Oct 27, 2006 | 06:44 PM
civicsit's Avatar
Default Re: anyone using COMP CAMS??? (92integraVTECgsr)
whats going on?
i am using comp cams stage 2 on my setup i got and i had portflow valve train plus a shaved head. even with a bad head gasket it still pulls al the way to red line and i have yet to have the car tuned to see what they can really do..
good luck hope this helped you some..
Old Oct 27, 2006 | 06:59 PM
sheepey's Avatar
Ive tried the stage 3 on a 2L 11.5 motor and compared them to our stage 3. It made like 4whp in some parts in the mid but from 7k and on the peak number wasnt as good as the webs. From all the sets ive seen the wear was bad because of the amount of lift they put on the vtec lobes.
Old Oct 28, 2006 | 12:30 AM
Default Re: (sheepey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sheepey &raquo;</TD></TR><TR><TD CLASS="quote"> From all the sets ive seen the wear was bad because of the amount of lift they put on the vtec lobes.</TD></TR></TABLE>
is this true? this is what ive read and heard that comp cams wears out the rockers? why is that? is this gonna be a problem?
Old Oct 28, 2006 | 08:50 AM
sheepey's Avatar
Yes its true. Ive cam doctored alot of sets. Rocket will even tell you. Anything over .310 lift at the cam will start to get you into retainer to guide seal problems , UNLESS your cylinder head is setup correctly. The guides will need to be machined down by your machinest for enough clearance. Good luck -- Alex
Old Oct 28, 2006 | 11:14 AM
91SiZ6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sheepey &raquo;</TD></TR><TR><TD CLASS="quote">Yes its true. Ive cam doctored alot of sets. Rocket will even tell you. Anything over .310 lift at the cam will start to get you into retainer to guide seal problems , UNLESS your cylinder head is setup correctly. The guides will need to be machined down by your machinest for enough clearance. Good luck -- Alex</TD></TR></TABLE>
Well, that answers that question.
I'm running the Comp 59300 with Comp springs and retainers.
Old Oct 28, 2006 | 07:16 PM
Default Re: anyone using COMP CAMS??? (civicsit)
so is it gonna be safe for me to run these Cams? I will upgrade the valve springs. But I dont want to ruin my rockers or screw up anything else.
How come other cams dont screw up the rockers? whats the difference between these and Skunk2 ProSeries Stage 2?
dohc_profile
Nov 13, 2007 08:32 AM
VvPeachyvV
May 6, 2007 11:32 AM
quicknadc2
Oct 26, 2006 08:13 AM
sirwags
Jun 5, 2005 03:51 PM
jdmoutlaw
Jul 26, 2004 06:53 PM
