compression question / skunk2 valves
alright im about to order my jdm itr 11:1 compression pistons.... im using a b16 head and i was thinking about getting the skunk2 high compression valves.... are those considerd oversized valves??? how much compression they actually add and what kind of compression would i be looking at with an oem 3 layer head gasket?? or a 2 layer gasket... im just worried bout decking... or is there anything to worry bout with that setup???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Drew17th »</TD></TR><TR><TD CLASS="quote">alright im about to order my jdm itr 11:1 compression pistons.... im using a b16 head and i was thinking about getting the skunk2 high compression valves.... are those considerd oversized valves??? how much compression they actually add and what kind of compression would i be looking at with an oem 3 layer head gasket?? or a 2 layer gasket... im just worried bout decking... or is there anything to worry bout with that setup???</TD></TR></TABLE>
Valves are generally available in both standard and oversized applications. The compression bump for flat faces is normally around .2-.3.
well im saying are the ones that bump compression oversized..... or can i get them in the standard size and they still bump it up....
First off Skunk2 valves are (supertech) valves just stamped S2and they also suck! so i would try for better vavles like ferrea! all the way! standard size only flat valves would be good for p73 slugs
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JakeSpec420 »</TD></TR><TR><TD CLASS="quote">First off Skunk2 valves are (supertech) valves just stamped S2and they also suck! so i would try for better vavles like ferrea! all the way! standard size only flat valves would be good for p73 slugs</TD></TR></TABLE>
wow you have 6 posts dont even talk
yeah only 6 post but,,,, built more motors than you've had in your lifetime. my homie works at skunk dont tell me what i already know! and dont try to talk ish!
if you dont know me!
Jakespec Fastest ALL MOTORstreet CRX in BALDWIN Park 12.00@113mph Spinning 1st and second! 1.875 60 ft!
sorry i dont spend my whole day on honda tech trying to learn everything!
EugeneERICK!
you generic!
EugeneERICK!
you generic!
prove it son . . .
prove it son . . .
oranginal
Apr 27, 2006 12:52 PM
red civic standard
Dec 12, 2005 08:49 AM
