Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
airbag light is on...dont know if this is srs light
Old Oct 27, 2006 | 10:26 AM
lv6l's Avatar
Default airbag light is on...dont know if this is srs light
04 civic ex 4dr.
a light ont eh dash is always on; the light is a guy sitting in his seat with the airbag in front of him. its on the bottom right hand corner of the dash. this is my friend's car, he bought it salvage. the light recently came on. what is going on? is this the srs light. im not familar with this model so if it is the srs does anyone know where the airbag harness is to jump and reset? thanks.
Old Oct 27, 2006 | 12:13 PM
Miracle's Avatar
Default Re: airbag light is on...dont know if this is srs light (lv6l)
If the car was a previously salvaged title, something may not have been replaced in the repair process.
Per the dealership, and Honda themselves, whom I have personally asked.... The computer that controls the SRS (Supplemental Restraint System) and the seat belt pretensioners have to be replaced after an airbag accident.
You will need to take the car to a shop, prefferabally a dealership and get the code read, and see what the computer is trying to say.
If you don't, the airbags will not redeploy in an accident, even though the airbags were replaced and operational. So until that code is read, the problem fixed, and the light reset, you won't have airbags.
Old Oct 27, 2006 | 12:14 PM
LowTec MOHawk's Avatar
yes that is the airbag light but the problem is that its not like the older honda's.....you cant just use a jumper to reset it. it has to be cleared by a factory scan tool. just bring it to the dealer
Old Oct 27, 2006 | 03:02 PM
susuking's Avatar
you can reset it thru the MES located in the fuse box below the stering wheel. you can use a jumper. but if your srs is throwing a code, you will not be able reset it. check this out.
http://www.7thgencivic.com/for...23977
Old Oct 27, 2006 | 08:13 PM
lv6l's Avatar
aitte. thanks for all the inputs.
Reaccion
Honda Civic (2006 - 2015)
24
Oct 20, 2017 11:26 AM
stattonmw
Acura TL, RL & ZDX
Mar 26, 2006 06:23 PM
94ls
Jul 1, 2005 06:50 AM
