hrater/ ac blower
Old Oct 27, 2006 | 10:11 AM
warman46's Avatar
Default heater / ac blower
2000 accord se ... Lost low speeds on blower, only have high. any suggestions?
Modified by warman46 at 2:19 PM 10/27/2006
Modified by warman46 at 5:39 PM 10/27/2006
Old Oct 27, 2006 | 11:55 AM
hondadude's Avatar
Default Re: hrater/ ac blower (warman46)
look under the hood for a sticker that says what year your car is; thats my first suggestion.
The blower motor resistor is the most probable cause of your problem.
Old Oct 27, 2006 | 01:20 PM
warman46's Avatar
Default Re: hrater/ ac blower (hondadude)
sorry, new at this.....2000 accord se...where would the resister be?
Old Nov 4, 2006 | 03:42 PM
blaupunked's Avatar
I'm having the same problem on my 2002 Honda Accord SE 4dr. I was also suggested to check the blower motor resistor. Would this be located under the hood or under the dash behind the glove compartment? Anyone have an estimated cost on a replacement and how easy it would be for a do-it-yourselfer to replace? Thanks!
Old Nov 4, 2006 | 05:50 PM
mnaines's Avatar
Default Re: hrater/ ac blower (blaupunked)
My dad had this happen in his Kia Sedona a couple times...Turned out to be the solenoid for the blower speed switch each time, so you might want to check and replace that, too. In his, though, it was exactly the opposite...He could not turn the A/C or heater on high, only on low, but simply replacing the solenoid for the switch solved the problem each time.
Old Nov 4, 2006 | 06:54 PM
ujhonda's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by warman46 &raquo;</TD></TR><TR><TD CLASS="quote">sorry, new at this.....2000 accord se...where would the resister be?</TD></TR></TABLE>
oh man How I am going to tell you this
OK it is right beside the recirculation control motor
Ok you know where is the blower motor - just look for removable square plastic piece with a 2 screw on it and that is your blower resistor.
you don't have to remove the whole blower unit.
marsulad
Honda S2000
Aug 23, 2012 12:59 PM
marsulad
Honda S2000
Aug 7, 2012 02:11 PM
HondasLast4Ever
Feb 23, 2011 05:21 PM
nramil
Oct 9, 2008 10:36 PM
