Civic wont start, injectors not getting power.
Old Oct 27, 2006 | 09:20 AM
Jrodk636's Avatar
Default Civic wont start, injectors not getting power.
I have a 96 Civic EX 5 speed. I recently put a used D16y8 in. Im not getting power to number 3 and 4 injectors. I used my harness from the old motor that ran fine. The car will turn over and fire just wont start. The night before I had the car started but wouldnt idle, but ran good above 2k RPM. I later found the big green connector near the ECU unplugged. After plugging it back in, I get no power to the 2 injectors. When I unplug the connector again, the same problem persists. I had a bad solder joint in the FI relay. I fixed that the pump now turns on normally. Im getting fuel to the rail and into the # 1 and 2 cylinders. I started to test for power back about 1 foot from the injector connectors. I wanted to make sure its not something stupid I looked over before I rip into the harness. Any advise??
Old Oct 27, 2006 | 09:25 AM
Sloshy's Avatar
FUEL PUMP FUSE
Old Oct 27, 2006 | 09:28 AM
Jrodk636's Avatar
Default Re: (hatch-E-vanish)
both good
SpoonCivicSir20
12
Sep 19, 2009 07:26 AM
shyboi4u
Nov 17, 2005 01:05 PM
