broke down
I ragged on my ej1 before the turbo warmed up and it just shut down. i cant get it to staert know it is cranking but it just wont start i have already ripped apart my fuel system and put it back togethert and everything checked out i am almost possitive i shorted something out in the ignition or ditributor i just dont know what.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -Gary- »</TD></TR><TR><TD CLASS="quote">Do you have spark?</TD></TR></TABLE>
Start there. Then look at your fuses.
Any CELs? What ECU/Tuning program are you using?
im not positive that i dont have spark, but i took out a plug and a wire and tested it, but nothing happend i am not sure i did this correctly thats why im not to sure if i have spark or not.i checked all my fuses under the hood, all were good. is therer a way that the fuses inside the car is causing it.
thnx for the help though.
i saw my dad put on a rubber glove, hold a screwdriver by the handle with the other end in the spark plug wire, and tapped the screw driver on the valve cover or something else metal to try and see a spark while i cranked it.
not the safest way but it's basic electricity
Ls_V_TurboSi
Feb 2, 2006 08:53 AM
MugenFlaredCRX
Dec 16, 2005 06:08 PM
