all-motor build over 200whp (need your help)
i want to do an all motor build on an b18b1 block, i need your help, what are the best parts that are out there to use, im looking to get over 200whp
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zap »</TD></TR><TR><TD CLASS="quote">search man.
there are lots of build up thread here that can guide you.</TD></TR></TABLE>
on a b18b1 block aka LS block your best bet to hit over 200hp (even tho its not about your Peak HP number but more of where your power and torque curve/band are) is to change out those horribly small valve reliefed flat dome pistons.
If you have money go with forged if not then there are plenty of competant OEM pistons that you can swap in, Id liek to suggest either a set of JDM b16 or JDM ITR pistons.
I would then also look into getting yourself a b16/gsr cyl head( for the main fact that its vtec and that it flows muchhh better then your crappy LS)
get yourself cams, gears, springs and retainters ( if your low on money a set of OEM CTR's are pretty good and close to the skunk2 stage 1's)
thenn get yourself a good header( NOT a SHITTY dc header, get a real 4-1, once again if ur on a budget id suggest the jdm ITR header for its 2.5inch collector)
thenn get yourself some bigger intjectors(310's or if ur broke dsms)
and of course get somesort of tuning( not a best guess chip bu either hondata or if ur broke chrome or something similar) and a competant tuner who knows what ere doing,.....
These arent all the peices need to build this setup reilablely(b/c it is an ls/vtec) you will need to swap out other parts, mostly on the bottom end for there vec counterparts (i.e water pump oil pump timing belt) and arp hardware ( rodbolts)
and one more thing get a light flywheel and something like a jdm b16 or itr transmission for those nice short gears for all motor
I would not expect to get 200whp streetable without going LS-VTEC. I haven't seen any dynos higher than low 180's whp on pretty well-built B18B engines.
I'm not dissing the engine, those are still impressive numbers and I always like to see people challenge themselves how far they can take an underdog. But if your specific goal is over 200whp it will be easier, just as cheap, and more reliable to go VTEC.
203.8 whp on an ls/vtec... b18a1 block stock crank eagle rods wisceo 12.5.1 cr..... b16 head unported.... supertech valves springs retainers....peak performance cams
81.5mm nore... rage header , victor x intake mani... 68 mm tb 3 inch intake hondata
From: Streets of Sacramento...But now living in So Cal, usa
dd 1.8 ls vtec.....217 whp 139tq (full ex. 2.5 inch piping es muffler) on a dyno jet
pnp gsr head (milled 000.15)
blox b cams
blox im - itr tb
pro fab header
ls block
usdm p73 pistons on stock rods (arp bolts)
jdm type r tranny 4.7 fd
blox b cams
blox im - itr tb
pro fab header
ls block
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elivtec »</TD></TR><TR><TD CLASS="quote">theres no replacement for displacement when it comes to all motor
i'm running 11.5 compression
a good reliable street compression with good bolt ons and a kick *** tune...
you'll net 200+
my set up grounded 205whp with filter and full exh
you'll net 200+
GEN2 LS
18
Oct 9, 2008 06:00 AM
theslugbug
Nov 18, 2003 05:00 AM
