1990 Accord Power Windows stopped working..
Old Oct 26, 2006 | 09:50 PM
Myh4tch's Avatar
Default 1990 Accord Power Windows stopped working..
I need some help troubleshooting this problem, I was re-running speaker wire on my driver side door, took off the door panel unclipped the harness for the p/w windows and mirror switch and took off the door panel. I finished re-wiring up the speaker (had to re-run the wire through the firewall so I was working in that area) and put everything back together, hooked up all the harness etc etc.. Went to roll down my windows and nothing. Checked the fuses both in the cabin and under the hood, checked the relay now im stuck. Any ideas?
I also checked to see if the passenger side window would work by trying to open it from its switch on the passenger side and no luck their either... So now im real stumped.
Modified by Myh4tch at 5:51 AM 10/27/2006
Old Oct 27, 2006 | 04:51 AM
Myh4tch's Avatar
morning bump
Old Oct 27, 2006 | 12:12 PM
hondadude's Avatar
Default Re: 1990 Accord Power Windows stopped working.. (Myh4tch)
are you sure you plugged in everything in the drivers door panel? The big fat black wire that is the ground for the system is a plug by itself.
Chris Reese
Jul 13, 2016 07:14 PM
j4s0n1337
Apr 4, 2012 07:28 AM
Lou_EM1
Jan 9, 2012 10:16 AM
Rayz_Si
Apr 21, 2008 06:17 PM
willyd88
May 18, 2006 07:53 PM
