Oil Pressure Light....
After changing the oil, do I need to reset the oil pressure light? I know some cars require you to reset the oil pressure light so it turns off. If so, how do I go about doing that?
Guess: i dont think you have to reset it, but if it does need to be reset, just unhook the negative battery terminal for like 15 seconds. that is the easiest way. WARNING: make sure if you have an OEM radio that you have the security code or else you just ruined that stereo.
