P72 vs Pr3 heads
Old Oct 26, 2006 | 05:55 PM
Amped's Avatar
Default P72 vs Pr3 heads
I have a 94 Gsr motor that i am rebuilding. I found the cam journals on my p72 head are scored so i found a guy with a "Pr3" head. He said it's from a 2001 integra. How much different is this head from the P72? I also have a Blox intake manifold for a gs-r soo im kinda stumped wheather not to buy this. I think the years of compatability are 94-01 right?
Thanks H-T
Old Oct 26, 2006 | 06:36 PM
nokturnal_munkeeboy's Avatar
Default Re: P72 vs Pr3 heads (Amped)
pr3 is b16 head, you have to modified the p72 block with pr3 head , to me it not worth it.
Old Oct 27, 2006 | 04:18 PM
Amped's Avatar
Default Re: P72 vs Pr3 heads (nokturnal_munkeeboy)
what do you mean "modify" what does it require. i thought type r & gsr block's are mostly interchangable.
Old Oct 27, 2006 | 04:55 PM
doood's Avatar
been there done that
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nokturnal_munkeeboy &raquo;</TD></TR><TR><TD CLASS="quote">pr3 is b16 head, you have to modified the p72 block with pr3 head , to me it not worth it.</TD></TR></TABLE>
what are you smoking? a pr3 head requires no modifications to install onto a b18c block.
Old Oct 27, 2006 | 05:03 PM
Amped's Avatar
Default Re: P72 vs Pr3 heads (sticky icky)
What do you think i should do? will i get noticable gains with the type r head over a gsr with my setup?
Old Oct 27, 2006 | 05:36 PM
GSRCRXsi's Avatar
the blox gsr mani wont fit on the pr3 head.
pr3 head will also lower your compression by about .2-.3
Old Oct 27, 2006 | 06:37 PM
mar778c's Avatar
Community Builder
Community Influencer
PR3 head can be either type R or b16.
Old Oct 27, 2006 | 07:07 PM
GSRCRXsi's Avatar
Default Re: P72 vs Pr3 heads (mar778c)
he's already said it was a type r...
Old Oct 27, 2006 | 08:43 PM
Combustion Contraption's Avatar
P72 for a street app.
Old Oct 27, 2006 | 09:09 PM
ipodhustle's Avatar
lmao
Old Oct 27, 2006 | 09:43 PM
JakeSpec420's Avatar
GSR p72 ALL THE WAY!!! Square CHAMBER!
xshytlipsx
Jan 23, 2009 10:50 AM
J Unit
Apr 30, 2007 01:54 PM
Amped
Oct 27, 2006 08:48 PM
b19coupe
Nov 25, 2002 08:10 PM
blackR#663
Aug 19, 2001 06:15 AM
