89 CIVCI SI QUESTION
Old Oct 26, 2006 | 04:29 PM
kpop's Avatar
Default 89 CIVCI SI QUESTION
i have a 89 civic si. I'm planning on getting a zc motor for it soon.
my question is do i use the same MOUNTS, HARNESS, and everything else even the tranny.
For those of you that have a zc in ur ef plz let me knoe wat u did
thanks.
Old Oct 26, 2006 | 04:31 PM
Tippyman's Avatar
Default Re: 89 CIVCI SI QUESTION (kpop)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kpop &raquo;</TD></TR><TR><TD CLASS="quote">i have a 89 civic si. I'm planning on getting a zc motor for it soon.
thanks.</TD></TR></TABLE>
Yes, re-use stock everything. That's the beauty of a ZC. Since you have an Si, all wiring is even done for you. you may have to lengthen a plug or two, but nothing major.
Old Oct 26, 2006 | 04:52 PM
dubzz24's Avatar
Default Re: 89 CIVCI SI QUESTION (Tippyman)
Distributor plug is different but that's it. If you do a search you'll find out how to wire it up
Old Oct 26, 2006 | 05:07 PM
Tippyman's Avatar
I'm not sure about the dual cam, but the single cam ZC is the same as an Si.
Old Oct 27, 2006 | 01:41 AM
kpop's Avatar
Default Re: (Tippyman)
i was planning on getting the dual cam zc
Old Oct 27, 2006 | 02:34 AM
Contender25
Guest
Posts: n/a
Same thing, just need to take the distributor plug, depin it, and pin 5 of the wires back into it. There are 7 wires total, the last 2 are gonna go in the CAS, "cam/crank angle sensor" whatever, well anyways, those two are blue/green/ and blue/yellow i believe, thats it.
I would make sure that when you buy the motor to get at least half the harness on it if not the whole thing, because it will have the two plugs you will need to switch over to your engine harness, and don't try to use the one that comes with the engine from japan, because your life will be void, period.
Old Oct 27, 2006 | 07:51 AM
dynamitezz's Avatar
Default Re: (kpop)
Go SOHC!
Old Oct 27, 2006 | 08:30 AM
wiZCo's Avatar
Stouts 'n' Scotch
Yes, everything will bolt right up, you can even use your Si trans if it's within the same year range (the year of your ZC will be stamped between the #2 and #3 exhaust ports). You will have to re-wire the dizzy plugs, or you can get a converter form rywire.com.
Old Oct 27, 2006 | 11:42 AM
kpop's Avatar
Default Re: (wiZCo)
im planning on getting the motor next week
ill let u guys knoe wasup
Old Oct 27, 2006 | 05:07 PM
Contender25
Guest
Posts: n/a
Might as well get the sohc, there gonna be the same power wise but the sohc zc is lighter plus more aftermarket support compared to the oddball dohc zc, but thats in my favor and opinion, you can do whatever you want.
Don't think your gonna get a dohc zc and just because it's dohc you think it's gonna be fast as a b16, because it's not, at least with the sohc zc you will have better option/route's to go with on mods.
Chadimus
May 29, 2007 11:19 PM
RJae-T
Feb 13, 2006 03:41 PM
Sharpview
11
Dec 8, 2004 11:37 AM
99sonicbluegsr
Sep 27, 2004 11:22 AM
Phelix
17
May 13, 2004 06:28 PM
