Cooling/Fuel?
Old Oct 26, 2006 | 02:26 PM
skytech76's Avatar
Default Cooling/Fuel?
Hi, anyone of you guys using this products before on your Honda. The brand is MOC Cooling-Sytem Treatment and Fuel-System Flush I get it for free, just want your opinion. Is the cooling-system treatment save to use on my 95 accord?
Old Oct 26, 2006 | 07:45 PM
BlUAc's Avatar
Default Re: Cooling/Fuel? (skytech76)
my boy has that red line cooling-sytem treatment in his supra turbo it hella helped his ride dont no bout your stuff though
Old Oct 27, 2006 | 03:00 AM
skytech76's Avatar
Default Re: Cooling/Fuel? (BlUAc)
Thank, I try to use this MOC cooling treatment cause i don't want to change it yet.
Here what is said on the bottle:
THIS WATER-PUMP LUBRICANT & RUST INHIBITOR HELPS STOP CORROSION AND RUST FORMATION WHILE ENHANCING THE CHEMICAL BALANCE OF THE COOLING SYSTEM. DESIGNED FOR USE WITH ALUMINUM & PLASTIC COMPONENTS.
Just want to make sure it safe to use on Honda Accord cooling system.
Old Oct 27, 2006 | 08:28 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skytech76 &raquo;</TD></TR><TR><TD CLASS="quote">... Just want to make sure it safe to use on Honda Accord cooling system.</TD></TR></TABLE>I don't know, but it seems like the Honda cooling system isn't the only thing. It ALSO has to be compatible with the anti-corrosion package of the antifreeze. There's several types of packages out there, & not all compatible with each other. Seems even less likely to be compatible with this type of product.
Old Oct 28, 2006 | 01:55 AM
skytech76's Avatar
Default Re: Cooling/Fuel? (JimBlake)
O.K, then I will change my antifreeze. Can someone tell me where is the bleeder screw is or direction on how to flush the cooling system? If I understand, drain the coolant, fill with water start engine, drain it and refill new coolant?
Old Oct 29, 2006 | 07:23 PM
JimBlake's Avatar
Turn your heater temperature all the way to hot, so the heater core can drain. There might be a drain plug in the back of the engine block, near the oil filter (not sure about '95). I usually take out the thermostat so it can circulate faster, without waiting to warm up.
Drain, fill, start the engine for a minute to mix it up. I usually have to drain/fill a few times before it drains out clear. My '98 has a drain plug in the block, but still there's about a quart or more that never drains.
The air-bleed screw would be on the thermostat housing, if '95 has one.
After you think all the air is bled out, let it cool down. Squeeze the lower radiator hose & listen for sloshing noises. All you should hear is the little rattle-pin in the thermostat. Sometimes I have to squeeze & push the hoses around, to push air bubbles towards the radiator cap or towards the thermostat (bleeder).
11L tech
Nov 8, 2018 06:12 AM
wkellcy
Jun 18, 2018 09:29 AM
saintx94accord
Paint and Body
Sep 29, 2012 09:16 PM
Mint01
Audio / Security / Video
16
Sep 27, 2007 07:11 PM
RHDintegXsi
Jul 4, 2007 05:02 PM
