another f22b dohc question????
Old Oct 26, 2006 | 02:01 PM
Six1oooEG's Avatar
Default another f22b dohc question????
which headgasket is used in this motor? wll one from a sohc f series work? also which water pump is used? i heartd u use one from a B series is this true? and also what timing belt? i just want to clear things up cause im in the middle of doing the headgasket and im stuck.
thanks in advance
Old Oct 26, 2006 | 05:45 PM
momstaxi's Avatar
Default Re: another f22b dohc question???? (Six1oooEG)
i always thought h23 parts work...
Old Oct 27, 2006 | 03:42 PM
Six1oooEG's Avatar
Default Re: another f22b dohc question???? (momstaxi)
nah man cmon someone on heres gotta know
Old Oct 27, 2006 | 05:57 PM
momstaxi's Avatar
use an h23 headgasket and any f-series waterpump
Old Oct 27, 2006 | 06:08 PM
Slomies's Avatar
JDM F22B DOHC = F22Ax (bottom end) / H23a1 (top end)
so you'd use an h23 head gasket and f22ax water pump
for the belt it's an h23 i believe, but just to be sure, just take yours to the local auto store and get one of the same length
Old Oct 28, 2006 | 12:04 PM
Six1oooEG's Avatar
Default Re: (Slomies)
ok thanks for the info guys! i heard the h23 has a bigger bore wouldnt that affect using a h23 headgasket the bore on the f22b is smaller wouldnt it not seal properly? i duno just a thought ...
Old Oct 28, 2006 | 07:23 PM
The G-Man's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slomies &raquo;</TD></TR><TR><TD CLASS="quote">JDM F22B DOHC = F22Ax (bottom end) / H23a1 (top end)
for the belt it's an h23 i believe, but just to be sure, just take yours to the local auto store and get one of the same length</TD></TR></TABLE>
NOT TRUE!
The H23 has a larger bore, and FRM sleeves.
As far as I know, you would use F22Ax headgasket because the bore is identical to the F22Ax sleeves.
Old Oct 29, 2006 | 01:09 AM
momstaxi's Avatar
Default Re: (The G-Man)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The G-Man &raquo;</TD></TR><TR><TD CLASS="quote">
NOT TRUE!
As far as I know, you would use F22Ax headgasket because the bore is identical to the F22Ax sleeves.</TD></TR></TABLE>
an f22b cylinder head is the same as an h23 head, the bore difference doesnt matter. a 2mm difference in bore wont matter as far as the gasket is concerned.
Old Oct 29, 2006 | 06:12 PM
Six1oooEG's Avatar
Default Re: (momstaxi)
ok anyone else wana share with us wat they think? im guessin the h23 gasket is the way 2 go thanks for the replies so far guys keep em comin very helpful
Zerob16eg
Jun 10, 2005 03:18 PM
kerris92lude
May 9, 2005 07:24 PM
TS4L
Mar 12, 2004 01:43 PM
ludesleep
May 18, 2003 07:14 AM
