96 S prelude engine swap to H22 vtec
Old May 5, 2002 | 10:18 PM
crapSlude96's Avatar
Default 96 S prelude engine swap to H22 vtec
Does anyone own a 4th gen S prelude and have swapped a H22 engine into it? Im considering having it done to my 96 S and I would just like to know if its a relatively easy swap for someone to do { I imagine it is}
Old May 5, 2002 | 10:55 PM
kevie88's Avatar
Default Re: 96 S prelude engine swap to H22 vtec (crapSlude96)
Yeah, I've done it, and it's probably the easiest of all Honda swaps. Everything bolts up perfectly like the engine was meant to be in there or something! ( )
As you have a 96 (OBD 2) car I would stick to getting a 96 and up H22 to cut down on wiring troubles!
[Modified by kevie88, 12:57 AM 5/6/2002]
Old May 6, 2002 | 06:14 AM
H22Si's Avatar
Default Re: 96 S prelude engine swap to H22 vtec (kevie88)
I agree completely. Also keep an eye out for an older ('93-'96, M2F4) transmission. The gearing is a lot better than the newer 5th Gen transmissions.
Old May 6, 2002 | 05:54 PM
Import RP's Avatar
Default Re: 96 S prelude engine swap to H22 vtec (H22Si)
Yeah, the ('93-'96, M2F4) kicks ***
Old May 7, 2002 | 02:58 AM
kevie88's Avatar
Default Re: 96 S prelude engine swap to H22 vtec (Pyrochaos38)
get the M2B4 if u can, same everything as the M2F4 but with LSD.. woohoo!
micah_m
Dec 8, 2008 08:23 AM
The-Kid
Jan 30, 2007 09:23 AM
stealthlude
Sep 5, 2005 10:13 PM
7808
Aug 29, 2003 04:12 AM
