horse power modi
what is this and how do you do this
7. Replace the flowmeter in the intake tract. If you will be using the motor above 6000 rpm frequently this can provide another 5 or so peak HP.
The flowmeter is very restrictive and limits HP above 6000 rpm, replacing it eliminates the bottleneck. The OEM flowmeter flows 165 CFM while a bone stock 1.6 motor at 7200 rpm flows 178 CFM, this means that the OEM unit is undersized for high rpm usage, the change probably won't be noticed below 6000 rpm.
i got it from some page where it says horsepower modification or something like that and i read it and thats the same thing i said what i though you all might know
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Capt. Blonde Beard »</TD></TR><TR><TD CLASS="quote">que... le.... ****....
Someone took French someone took French
raverx3m
Apr 29, 2012 06:06 AM
90teg
May 2, 2006 02:14 PM
