A/C question
Old Oct 26, 2006 | 11:43 AM
89accorn's Avatar
Default A/C question
Would an 89 accord dx carb. have a thermostat behind the glove box?
Old Oct 26, 2006 | 03:00 PM
hondadude's Avatar
Default Re: A/C question (89accorn)
Yes, it wraps around the Evap case and sticks into the case to shut off the A/C if the temp gets close to freezing up the Evap.
Old Oct 27, 2006 | 10:41 AM
89accorn's Avatar
would it keep the A/C system from working entirely if it was busted?
Old Oct 27, 2006 | 11:49 AM
hondadude's Avatar
Default Re: (89accorn)
yes it would break the electrical path to the compressor clutch.
You might consider a schematic if you are trying to diagnose the system, those thermostats rarely fail. There are a lot more common problems, does the system have freon in it? have you check the rear window defrost fuse? That fuse is shared with the A/C clutch coil.
JeremyGonzales
Jul 29, 2018 02:00 AM
aniskhan
11
Jul 8, 2018 02:32 PM
jjrek9
Jul 31, 2012 07:00 PM
JettCRX
Jul 9, 2006 07:52 AM
maivla01
Jun 8, 2006 08:06 PM
