Need Brake light help?
Old May 5, 2002 | 09:59 PM
teamunleash's Avatar
Default Need Brake light help?
I need help with my brake light? when i step on my brake pedal on my 90 dx hatch, the brake light dont turn on? has this ever happened to anyone? please respond back with what u think? thanks...
Old May 5, 2002 | 10:18 PM
WuShu's Avatar
New User
Default Re: Need Brake light help? (teamunleash)
does it turn on when your parking brake is on? if not its probably the sensor or wire for the pedal.
Old May 5, 2002 | 10:29 PM
MilanoRex's Avatar
Default Re: Need Brake light help? (HondaCRX)
did you check the bulbs and fuses?
Old May 5, 2002 | 10:52 PM
Louie B.'s Avatar
First off, I'm assuming you are refering to your brake lights on the back of the car and not the one in the dash. The brake pedal only lights the bulbs on the back of the car, the e-brake ONLY lights the warning light in the dash.
If all 5 brake light bulbs aren't lighting up, it's most likely either the fuse or the switch. First, go for the easy fix, check your fuses. You have 2 fuse boxes, one under the dash, and one under the hood on the right strut tower. I forget which one has the brake light fuse, but it should be labled.
If your fuses are good, look at the brake pedal itself. If you follow the pedal up you should see a switch up twards the pivot point. When you press on the pedal, you should see the switch operate (you can usually also hear it click.) check the wires going to the switch and make sure they're conected properly.
If all of this checks out good, then you either have 5 burned out bulbs, or some wiring problems. Unless you have the right test equipment and knowlege of wiring systems, I'd sugest taking wiring probs to a professional.
Old May 6, 2002 | 02:18 AM
Chiovnidca's Avatar
Default Re: Need Brake light help? (thumpu77)
The switch on the master cylinder cap also turns on the brake warning light. That way you know when your brake fluid is getting low.
Old May 6, 2002 | 08:44 AM
i checked all the fuses and all the bulbs before, the parking lights the only problem is when i step on the brake pedal, the light doesnt turn on.
prelude_93vtec
Nov 26, 2007 01:57 PM
irishbobby23
Aug 31, 2006 12:23 PM
5speed4life
Apr 25, 2005 12:23 PM
Bishop Don Shizzle
Jan 2, 2004 06:23 PM
HyBriDcxR
Aug 9, 2003 11:46 AM
