welding thinner material on 60amp mig
Old Oct 26, 2006 | 08:03 AM
LostAndFound's Avatar
Default welding thinner material on 60amp mig
Im still new to all of this, but I found when experimenting with stick welding, on too thin of a piece of metal, and it was an older stick welder so I couldnt go with any less amps, the only way I could weld without blowing through was to start stop start stop.
For thinner metals, and without need for much structural support or perfect welds, can I use this pulse/start stop start stop method. My mig only goes down to 60amps (I got it cheap enough to justify it) Or am I still going to blow holes. Sheetmetal for example, would I be able to do this or at least tack it well.
Old Oct 26, 2006 | 08:18 AM
Default Re: welding thinner material on 60amp mig (LostAndFound)
PS - flux core only, no gas
Old Oct 26, 2006 | 03:27 PM
drewzilla's Avatar
I havent stick welded in a couple of years but im pretty sure 60 amps is going to thrash sheet metal. Maybe you could hit it real fast and whip it out and it would tack. It all depends on the thickness of the metal and the kind of rod you use. Also all stick welding uses flux.
Old Oct 26, 2006 | 03:39 PM
lkailburn's Avatar
i was recently attempting this. welding very thin metal with stick. i tried turning the amps way down to like 20 but it would kill the arc mid weld. turning it up more would typically burn through.
solution: probably turn it to liek 30ish depending on thickness and work VERY FAST.
im a noob at welding so just keep practicing with settings until you can find one that manages to weld the meterials together
Old Oct 26, 2006 | 03:56 PM
Default Re: (lkailburn)
my fault i made it sound like i was still stick welding. that was just a technique i used when i was stick welding, now I have a flux cored mig welder. Just wondering how this method would work at 60amps with flux cored wire. 60 amps is my lowest setting
Old Oct 28, 2006 | 01:40 PM
lkailburn's Avatar
60 is the lowest? hrm maybe up the spool rate and go really fast so that the heat doesn't burn through?
im not really sure. hopefully someone a lil more wise can lend an opinion
Old Oct 28, 2006 | 02:12 PM
jeremydde's Avatar
How big is this machine? The lowest on my lincoln mig is 30amp, which using .023 wire can still burn through thin sheetmetal, but can be controlled with copper held behind the weld. My welder is using c25 gas though. Try copper behind the weld is all I can suggest.
Old Dec 14, 2006 | 12:36 PM
fventura03's Avatar
Default Re: (jeremydde)
i'm going through this too, 60amp is the lowest i have also, i keep burning through the sheetmetal, anyone else have any other tips?
duffman1278
Welding / Fabrication
Dec 16, 2009 05:49 PM
grju22
Paint and Body
May 27, 2009 11:04 AM
thw_goalie
Paint and Body
22
May 4, 2008 10:27 PM
swatteamtimmah
Jun 20, 2006 04:12 AM
dkim48
21
Dec 11, 2005 03:22 PM
