Brake upgrade, can't remember something...
Old Oct 26, 2006 | 05:46 AM
JokerTypeR's Avatar
Default Brake upgrade, can't remember something...
For the master cylinder in these things, you can run the EX 4dr sedan model master cylinder (15/16"). Just making sure that's the right car, right?
Also, what was the upgrade for the brake booster on that? Same car or was it the teggy? I remember one required no mods...
Old Oct 26, 2006 | 05:58 AM
CRX Toad's Avatar
Default Re: Brake upgrade, can't remember something... (JokerTypeR)
You can run the 15/16" MC from the EX is it a bolt on affair. I had one for a little while and passed it off to my bro in law when I got the Integra booster and MC.
The Integra booster and MC will shorten the travel for the brake pedal in relation to the braking power. The best on for the street is the 90+ Integra non ABS booster and MC they have a tag on them that should read 260v.
If you get the Integra ABS booster and MC is it will be marked as a 290v and you must change the fitting on the back line is different than our cars.
Old Oct 26, 2006 | 07:25 AM
JokerTypeR's Avatar
Default Re: Brake upgrade, can't remember something... (CRX Toad)
I'll have my eyes out for a 260v then...thanks, man! Always there to help, aren't ya.
Old Oct 26, 2006 | 11:28 AM
HonDelso's Avatar
use an RS integras one they will bolt up right no modfication
Old Oct 26, 2006 | 11:37 AM
Tyson's Avatar
Default Re: (HonDelso)
booster is bigger on the EX too.
http://www.norcalcrx.org/tyson/brakepartslist.xls
the prelude and accord MC is 15/16 as well, but the ports are a bit different, but totally bendable and usable.
Old Oct 26, 2006 | 12:21 PM
JokerTypeR's Avatar
Default Re: (Tyson)
So both the 260v Integra and booster as well as the EX booster and combo have 15/16's MC's and both are direct bolt on, no mods required and they'll have similar pedal travel...correct?
Old Oct 26, 2006 | 12:59 PM
Tyson's Avatar
Default Re: (JokerTypeR)
i believe the integra MC need to be mounted with the integra booster. otherwise the MC integra doesnt line up to the civic booster.
someone can correct me if im wrong.
Old Oct 26, 2006 | 01:02 PM
CRX Toad's Avatar
Default Re: (Tyson)
Yes, Tyson is correct. Integra booster must stay with Integra MC. And vise versa.
Integra setup will give you less pedal travel. Which in my opinion I like it that way.
Old Oct 26, 2006 | 03:16 PM
Wes V's Avatar
Default Re: (CRX Toad)
Wait a minute there Mr Toad.
If both the EX and Integra master cylinders are 15/16, the pedal travel should be the same.
It's possible that the "boost" is different between the EX and Integra boosters and that would effect pressure required at the pedal, but the throw should be strictly a function of the cylinder bore.
Wes
Old Oct 26, 2006 | 03:28 PM
Tyson's Avatar
Default Re: (Wes V)
pedal effort could be easily confused with pedal travel i think.
Old Oct 26, 2006 | 05:08 PM
CRX Toad's Avatar
Default Re: (Wes V)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Wes V &raquo;</TD></TR><TR><TD CLASS="quote">Wait a minute there Mr Toad.
Wes</TD></TR></TABLE>
It is the pedal effort due to the booster. Which is going to affect the actual travel of the pedal. With the EX MC on my car the pedal effort was slightly less than stock. Now with the Integra booster and MC the effort is so light that it greatly reduces the travel of the pedal.
To do the same amount of braking I get into the pedal around 1/2"-1" with the Integra setup. The EX MC was going a good 5"-7" of pedal travel.
I completely understand what you are saying but the booster is where the difference is. You also have to remember that the rod in the booster can also reduce the pedal travel. Hence why the 290v booster and 260v MC can't be switched, or ABS vs non ABS which ever you prefer.
Old Oct 26, 2006 | 06:06 PM
Wes V's Avatar
Mr. Toad;
I'm glad you didn't take that the wrong way.
Wes
Old Oct 26, 2006 | 07:49 PM
JokerTypeR's Avatar
So the final call is that the Integra is better to go with as it will provide me with less pedal travel as well as an easier-to-push pedal, right?
Old Oct 26, 2006 | 07:52 PM
Tyson's Avatar
just as long as you realize it doesnt affect your power at the calipers. its simply user preference and comfort.
however, if you do need to upgrade MC when you make both front and back brakes bigger. or else you will have too long of pedal travel, and possibly not enough.
Old Oct 26, 2006 | 07:59 PM
JokerTypeR's Avatar
Default Re: (Tyson)
See I was always under the impression you could upgrade with DA rear discs, and DA front discs and keep the same MC/boost so long as you switched to the 4040 prop valve (already done). So now I guess I should be looking at getting that MC/booster sooner than planned, I suppose...
Old Oct 26, 2006 | 08:01 PM
Tyson's Avatar
no. EF_status did that and found a very long pedal travel. he needed a bigger MC. its simple hydraulics.
like i always recommend, dont change your brake parts in pieces, try to transfer or mimic the complete system from the donor car.
Old Oct 26, 2006 | 08:04 PM
JokerTypeR's Avatar
Default Re: (Tyson)
Wish I had...
Is it safe to be DD with it having the regular MC/boost and the DA discs until I can switch it over, or is it like a "MUST DO NOW" type of thing?
Old Oct 26, 2006 | 08:09 PM
Tyson's Avatar
just brake early. i would do it asap.
Old Oct 26, 2006 | 08:14 PM
JokerTypeR's Avatar
Default Re: (Tyson)
Hmm...I'll probably go ahead and get it done. I think my breaks have air in the lines and leak of fluid because the paint is chipping away on the booster between it and the MC. I think it may be time to go ahead and upgrade it as well, bleed them with one of those tools from autozone and just be done with it the right way and for the last time...fresh fluid and all.
Thanks, you three!
Old Oct 26, 2006 | 08:16 PM
Tyson's Avatar
eh? what bleeding tool?
do it the right way. use 2 people.
to save time, i found that you dont have to open/close for every pedal pump. just make sure the hose arcs up a few inches so that theres always a good amount of fluid above the nipple and you can pump repeatedly before closing it. makes the process MUCH quicker, and less hectic. just be careful, you go thru more fluid much faster, so dont forget to check the reservoir.
Old Oct 26, 2006 | 08:20 PM
JokerTypeR's Avatar
Default Re: (Tyson)
Yeah, Autozone has a rent-a-tool that I guess sucks the fluid out? I don't know, but I've seen it in a picture somewhere...
Anyways, the brake fluid last time I bled it I pumped out and put through like a bottle of fluid while bleeding. It still came out pretty brown and chalky, though. So what I was thinking is just get that vacuum tool and suck a ****-ton through each individual line and try to get ALL the air out...cuz it feels like there's air after my last bleed job...
Old Oct 26, 2006 | 08:24 PM
Tyson's Avatar
dont use a vacuum tool. it doesnt work well, and youll get blisters. yes, ive used it before. it also sucks air through the threads and back into the caliper. not a good thing.
get anyone off the street to help you. its much easier and effective that way.
you need at least one bottle to do a complete flush.
Old Oct 26, 2006 | 08:39 PM
JokerTypeR's Avatar
Default Re: (Tyson)
I think I can find a female friend confident enough to push a pedal
Old Oct 26, 2006 | 08:45 PM
EF_ST@TUS's Avatar
Looks like all is well here.... Lemme know if anyone has questions related to this topic.
I have done the integra brake swap all the way around.
for 10.3 front rotors.
Old Oct 26, 2006 | 08:48 PM
Bjorn20's Avatar
Default Re: (Tyson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">just as long as you realize it doesnt affect your power at the calipers. its simply user preference and comfort.
no difference at the power at the calipers meaning no difference in better stopping power?
putting say 90-93 integra brake rotors (which are bigger than the ef's) will increase stopping power right? With those rotors, do you need the same year caliper, pads, master cylinder, brake booster? Ive also heard that you can use DOT4 with this? Is there more parts to that brake upgrade then listed?
