Ok probly have heard this before.....
have two CRX one SI the other DX, Si body beat up so decided to use DX which already had zc swap. took wiring harness from si put into dx, the engine cranks but no spark, i have the ZC ECU which, i have a little spark from one plug when the key is turned on or off. WTF and what do i look for, what should i get to make this work? please any help would be appreciated.
did you just use the si engine harness or the whole harness? you need to modify the dx harness, the si harness will not work, unless you use the whole si cabin harness etc. in the dx
yup whole harness from the si, tail light to head light, including engine. the si motor was sold before i could get the distributor, so i need the right parts to finish it........ what should i get?
it is a single over head ZC, and on the si wiring harness two wires going beneth the intake manifold pretty far from the distibutor so what does it go to? if it goes to anything? and is that my problem seriously im lost on this.
and im done on my 5 post
itztrixxx
Oct 26, 2006 07:25 AM
415Hatch
Jun 7, 2005 04:04 PM
bseriesboosted
Jan 29, 2004 12:55 PM
