Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
spark plugs?
Old Oct 25, 2006 | 07:19 PM
eseries07's Avatar
Default spark plugs?
ok so i think i narrowed down the ticking/chirping sound. its coming from the block and it seems to be the spark plug. skipped the 30k maintence. So the possibilities of my spark plugs being all messed up and janky and carodid[sp] are high. Can a carodid spark plug do such a thing if it isnt firing?
Old Oct 25, 2006 | 08:55 PM
Going Postal's Avatar
Default Re: spark plugs? (eseries07)
Yea, if you havent changed your spark plugs then you should change them. And you might need new spark plug wires. The sound could be a loose spark plug wire or ripped wire.
Old Oct 25, 2006 | 09:56 PM
YouGotHacked's Avatar
Default Re: spark plugs? (SoLOW916)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SoLOW916 &raquo;</TD></TR><TR><TD CLASS="quote">Yea, if you havent changed your spark plugs then you should change them. And you might need new spark plug wires. The sound could be a loose spark plug wire or ripped wire.</TD></TR></TABLE>
Ehm, One minor problem with this statement. The D17 has Coil on Plug ignition system, which....means.... No spark plug wires.
Old Oct 25, 2006 | 10:09 PM
Default Re: spark plugs? (01HonderCivic)
whoops forgot thought i still had a d16 civic still
Old Oct 25, 2006 | 10:19 PM
LowTec MOHawk's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eseries07 &raquo;</TD></TR><TR><TD CLASS="quote">ok so i think i narrowed down the ticking/chirping sound. its coming from the block and it seems to be the spark plug. skipped the 30k maintence. So the possibilities of my spark plugs being all messed up and janky and carodid[sp] are high. Can a carodid spark plug do such a thing if it isnt firing?</TD></TR></TABLE>
ummm if you have a d17 engine like i assume u do since your in the em2 forum then 30k miles on the factory plugs is nothing...........its not even recommended to change them until like 100k ( i have 40k on mine and they still look brand new) ......if your plugs are fouled then thats not the problem thats a symptom meaning u have a problem elseware causing that to happen........
Old Oct 26, 2006 | 01:26 AM
toyomatt84's Avatar
Sanji
Sounds like you're lacking oil, if it's a constant tick.
Old Oct 26, 2006 | 07:27 AM
iwantspeed's Avatar
Default Re: spark plugs? (toyomatt84)
is it bad to add 2 different brands of oil at once? kuzz i dont remember what oil i filled up with last. i do know i always use full synthetic but i dont remember the BRAND.. can i just add a little more of anybrand or is that gunna hurt sumthing?
Old Oct 26, 2006 | 08:15 AM
Default Re: spark plugs? (iwantspeed)
For this one time, no, you'll be fine.
Old Oct 26, 2006 | 11:28 AM
Boilermaker1's Avatar
a constant ticking sound while the car idling is the injectors firing. If it sounds like a real sloppy tick, then have the valves adjusted.
Chirping noises sound like a belt.
banginryder16
Nov 23, 2007 06:32 AM
JinDIESEL
Sep 18, 2004 09:36 PM
mickey513
Jul 23, 2004 05:38 PM
ptran
Jun 17, 2004 06:33 PM
wessieball
Jul 25, 2002 09:06 PM
