Squeaky/Creaky sounding clutch travel?
Old May 5, 2002 | 08:25 PM
avenger1281's Avatar
Default Squeaky/Creaky sounding clutch travel?
When I push my clutch in or let it out, I can hear a squeaky kinda creaking sound coming from outside.
Do you know what could be doing this?
Is this a bad thing?
Old May 5, 2002 | 09:16 PM
ck279's Avatar
Default Re: Squeaky/Creaky sounding clutch travel? (avenger1281)
I get that too. Mine tends to go away once the car has been driven for a good long time.....so I think it may be heat sensitive. For me, I replaced my clutch and although I lubed the **** out of everything I was supposed to, I guess I still didn't put enough on. My guess is it is the motion of the fork and clutch release bearing. They are the only major moving parts when you push the clutch pedal aside from the clutch itself.....but I don't think there is anything with the clutch assenbly itself that will sqeak. Especially if the car is not moving. You "could" take the boot off of where the slave cylinder mount and spray some WD-40, but I know they specifically say to use grease only on the moving parts in there so although that may work it would not be a good, or long term solution.
M-EJ1's Avatar
Mine does that too on my 95 coupe... I'm assuming a good shot of WD-40 in the right place will solve our problem... I haven't had time to look yet where to spray... might have to remove some stuff to get to the pivot point for the clutch pedal or the tension spring...
Old May 5, 2002 | 09:50 PM
sushibug's Avatar
i also have this problem and its annoying because you can hear it from far outside... it makes me feel more ghetto
Old May 5, 2002 | 10:02 PM
samdawgsol's Avatar
New User
Default Re: Squeaky/Creaky sounding clutch travel? (sushibug)
Yep same problem here. Sometimes I have to move my car manually from the outside to get the key to turn in the ignition, with the clutch pedal down alll the way. Its so ghetto. I think it something to do with some mechanical part of the transmission, but oh well it stiill turns though
[Modified by samdawgsol, 1:02 AM 5/6/2002]
Old May 6, 2002 | 05:39 AM
ineedboostbad's Avatar
Default Re: Squeaky/Creaky sounding clutch travel? (samdawgsol)
I have the same problem on a 97 cx hatch, haynes manual says nothing and there has been like 3 posts on it already, Who knows how to get rid of the squeek??
Old May 6, 2002 | 05:57 AM
Ricey McRicerton's Avatar
Default Re: Squeaky/Creaky sounding clutch travel? (LShbVTEC)
got the same thing on my 97 dx hatchy...also want to know how to get rid of the hood rattles and the rear suspension squeaks
Old May 6, 2002 | 06:30 AM
Default Re: Squeaky/Creaky sounding clutch travel? (Ricey McRicerton)
did the rear suspension start squeeking after you lowered it... i'm running Neuspeed Sport springs and have the same problem.
Dre_559
May 28, 2009 08:23 PM
otakueric
Oct 6, 2004 09:44 PM
sil99civic
Jan 20, 2004 08:44 PM
VintegraGSR96
Sep 5, 2003 05:34 AM
2fast4u
Apr 25, 2002 08:36 AM
