D series: GX pistons, what rings to use? Anyone use this setup yet?
I'm looking toward the Civic GX piston/LS rod setup for my motor.
What rings should I use? Is there a difference in size between the GX ringlands and other D series piston ringlands? Anyone have a part number for the GX rings (full ringset)?
You can look them up at http://www.slhondaparts.com or some other parts site that has the pn's.
13021-P07-G02 RING SET, PISTON (OS 0.25)
13031-P07-G01 RING SET, PISTON (OS 0.50)
13031-P07-G02 RING SET, PISTON (OS 0.50)
13011-PDN-A01 RING SET, PISTON (STD) (ALLIED RING)
not sure if these are correct.
DC2TT
Nov 11, 2005 10:44 AM
