b20 b18 b16 help. please
Old Oct 25, 2006 | 04:41 PM
b18hondahb's Avatar
Default b20 b18 b16 help. please
okay so i just got a b20a block a full block head and tranny from a b20a1 89 prelude and I could get more stuff also like b18 and b16. my question is what b20 block should I use for a b20 block and a b18 head and which head should I try to find. please start by the best to the crappiest. also what stuff do I need for a b18 block and a b16 head for that combo which ones and also what trannys will work and do great. thank you. also the b20 block with b18 head will go into a 88 crx dx and the b18 block with a b16 head will go into a 93 4 door civic.
Old Oct 25, 2006 | 05:12 PM
DC_RaceR's Avatar
Default Re: b20 b18 b16 help. please (b18hondahb)
It's called LS-Vtec.
Using LS or B20 non v-tec and mate it with a V-tec head...
1. Type R head
2. B16 head
3. Gsr head
B20 and LS B18a/b is about the same. I heard B20 has weak sleeves then B18..
DC_RaceR's Avatar
1. Type R head
2. B16 head
3. Gsr head
They all could fit in any honda with mounts and little mods.
Old Oct 25, 2006 | 05:47 PM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18hondahb &raquo;</TD></TR><TR><TD CLASS="quote">okay so i just got a b20a block a full block head and tranny from a b20a1 89 prelude</TD></TR></TABLE>
Let me be the first to say that you REALLY don't want to have anything to do with a B20A. They are poorly designed and share very very little with the later B-series engines (B16A, B16B, B17A, B18A, B18B, B18C, B20B, B20Z). There is very little information available and almost no aftermarket support for the B20A. I hope you didn't pay anything over its value as scrap metal.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">my question is what b20 block should I use for a b20 block</TD></TR></TABLE>
If you insist on having a B20, pick up a B20B or a B20Z from a CR-V.
Old Oct 25, 2006 | 07:22 PM
EF_9's Avatar
Default Re: b20 b18 b16 help. please (Targa250R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R &raquo;</TD></TR><TR><TD CLASS="quote">
If you insist on having a B20, pick up a B20B or a B20Z from a CR-V.</TD></TR></TABLE>
yep hes right
Old Oct 26, 2006 | 04:43 AM
b18hondahb's Avatar
Default Re: b20 b18 b16 help. please (EF_9)
okay so what b20 should I get a b20z or b20b for the ls vetec head.
Old Oct 26, 2006 | 05:55 AM
SIred91's Avatar
Rainman
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18hondahb &raquo;</TD></TR><TR><TD CLASS="quote">okay so what b20 should I get a b20z or b20b for the ls vetec head.</TD></TR></TABLE>
Dude, are you sure you know what you are even doing or want to do?
for an ls vtec head use:
B16 or GSR or ITR, that is: B18c1 and B18c5
or just a B16A.....screw the b20 heads. The only thing you want from a b20 is the block, and thats not an ls. The ls is the B18 from the early 90's teg, the vtec is the aforementioned heads.....and yeah, the prelude engine is **** for power or any kind of aftermarket other than for prelude fans.
spens 91 Ef
Oct 29, 2009 11:40 AM
street dreams
Mar 5, 2004 09:57 AM
