Dohc zc exhaust ports
Old Oct 25, 2006 | 04:26 PM
BlueRex1020's Avatar
Default Dohc zc exhaust ports
how much do you have to port an aftermarket d series header to much the exhaust ports on the Dohc zc?
Old Oct 25, 2006 | 04:38 PM
Default Re: Dohc zc exhaust ports (BlueRex1020)
match* sry lol
Old Oct 25, 2006 | 05:07 PM
jlicrx's Avatar
about this much:
Old Oct 25, 2006 | 07:10 PM
Default Re: Dohc zc exhaust ports (jlicrx)
thanx
Old Oct 25, 2006 | 07:11 PM
janz3n's Avatar
anyone know if the stock 4-2-1 exhaust manifold is worse or better then a d series header fit to work?
Old Oct 25, 2006 | 07:17 PM
Tippyman's Avatar
Default Re: Dohc zc exhaust ports (janz3n)
Just mod a d-series. Won't take too long with a dremel. Tons of people have done it. Hell, you don't even really need to, but most do...
Old Oct 25, 2006 | 10:18 PM
0oE's Avatar
0oE
Default Re: Dohc zc exhaust ports (Tippyman)
The stock ZC manifold is one of the better ones honda has made....i think
Old Oct 26, 2006 | 05:43 AM
Autoworks's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlicrx &raquo;</TD></TR><TR><TD CLASS="quote">about this much:
yup
It will vary a little between header manufacturers, but for the most part that's about it. It is a fairly easy process.
Old Oct 26, 2006 | 08:32 AM
ef8mugen's Avatar
Default Re: Dohc zc exhaust ports (Autoworks)
Is that gasket made of carbon fiber?
Old Oct 26, 2006 | 08:34 AM
Autoworks's Avatar
Default Re: Dohc zc exhaust ports (ef8mugen)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ef8mugen &raquo;</TD></TR><TR><TD CLASS="quote">Is that gasket made of carbon fiber?</TD></TR></TABLE>
huh
looks like a regular gasket to me
Old Oct 26, 2006 | 04:59 PM
Got_soy's Avatar
sounds like something you should add to your store
Old Oct 26, 2006 | 05:51 PM
janz3n's Avatar
Default Re: Dohc zc exhaust ports (Got_soy)
anyone els know if the stock zc header is better or worse then a d series aftermarket header? all i can see that a after makerket one would be good for is weight reduction.
Old Oct 26, 2006 | 06:03 PM
kingSfit's Avatar
pretty sure if you take it apart and clean all the grime and icky stuff in there it should do the same job... but as for weight maybe
Old Oct 26, 2006 | 07:24 PM
jlicrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by janz3n &raquo;</TD></TR><TR><TD CLASS="quote">anyone els know if the stock zc header is better or worse then a d series aftermarket header? all i can see that a after makerket one would be good for is weight reduction.</TD></TR></TABLE>
better than some and not as good as others - depends on which aftermarket header - it is kind of heavy
sean burke
Apr 20, 2009 05:34 PM
thenick
Oct 3, 2006 05:37 PM
Jmorin
Oct 2, 2003 08:00 AM
sabertooth
Apr 12, 2003 08:59 PM
tpr
Mar 13, 2003 12:22 PM
