Dynoed some ITB's with filters
Old Oct 25, 2006 | 04:13 PM
DonF's Avatar
Default Dynoed some ITB's with filters
Ran with out filters and with Jenveys filter. Lost 1 BHP on average from 7000-9400 and 2.2 peak above 9000.
Old Oct 25, 2006 | 04:18 PM
the_unknown's Avatar
GDD Lonely Krew
what does jenveys filter look like? individual cones or large filter material wrap? just curious, thanks.
Old Oct 25, 2006 | 04:19 PM
DonF's Avatar
Default Re: (the_unknown)
Trying to do pics, do not have that down yet.
Old Oct 25, 2006 | 04:24 PM
BolivianFuego's Avatar
Default Re: (DonF)
So this was all brake horse power(engine dyno), which = basically nothing to the wheels?
Old Oct 25, 2006 | 04:38 PM
DonF's Avatar
Default Re: (BolivianFuego)
Yes, engine dynos are useless, I just happen to be stuck with one. Wish I could get a Dyno-Jet like all the F-1 Mfg. and NASCAR engine builders use.
Old Oct 25, 2006 | 04:45 PM
Default Re: (DonF)
LOL I didnt mean it like that, u cant beat an engine dyno senor Don De la Vega. IM saying in translation to whp equiv. it comes out to almost nothing.
Old Oct 25, 2006 | 04:54 PM
DonF's Avatar
That I understand better, loss of about 1 WHP @ 9400 Trying to get a customer to post pics.
Old Oct 25, 2006 | 04:57 PM
Default Re: (DonF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DonF &raquo;</TD></TR><TR><TD CLASS="quote">That I understand better, loss of about 1 WHP @ 9400 Trying to get a customer to post pics.</TD></TR></TABLE>
There we go. U were about to E-bite my head off.
Old Oct 25, 2006 | 05:58 PM
lohatch's Avatar
Default Re: (DonF)
go to photobucket.com and upload the picture. then click on it so it pops up big and right click it and copy the "properties", then come on here, hit reply, and click the "insert image" icon above and paste the "properties" in between the
[IMG] [/IMG ]
if you aleady knew that, sorry to waste your time...just trying to help
nevermind you got it, but for future reference
insomniac791's Avatar
Default Re: Dynoed some ITB's with filters (DonF)
Her you go Don...Sorry it took so long..
Modified by insomniac791 at 10:14 PM 10/25/2006
Old Oct 25, 2006 | 06:04 PM
lohatch's Avatar
Default Re: Dynoed some ITB's with filters (insomniac791)
roughly how much does the filtration setup cost in US dollars??
and off topic but is there a certain crankpulley you personally prefer for the bvtec engine don?? i noticed you are running what looks to be a CTR pulley on this engine.
Old Oct 25, 2006 | 06:15 PM
DonF's Avatar
Thanks Matt, If the filter is kept away from the stacks is does not cause any air flow problems. The filter has a metal stay so it cannot be "sucked" in. It seens as long as the filter is stable, and free flowing "foam" it does not affect the mass air flow. I have had other filters on webers and plenum manifolds drop BHP numbers by very large numbers. I still think we need "box' and external air hose over these and it will pick up more "installed" BHP above 60 mph.
Old Oct 25, 2006 | 06:25 PM
No problem Don, I really like this setup maybe eventually I will switch over to it.
Old Oct 25, 2006 | 06:59 PM
DonF's Avatar
Default Re: Dynoed some ITB's with filters (lohatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lohatch &raquo;</TD></TR><TR><TD CLASS="quote">roughly how much does the filtration setup cost in US dollars??
and off topic but is there a certain crankpulley you personally prefer for the bvtec engine don?? i noticed you are running what looks to be a CTR pulley on this engine.</TD></TR></TABLE> That is a CTR pulley with a crank fire setup that I use on the dyno. That engine is actually getting a Fluidamper as his standalone will read off the cam. That engine is a GRS stroke so the CTR pulley would not bother me. 92-95-98 stroke cranks have more flex and ocilations and should have a dampner to help remove some ocilations ( not remove dampen) to prevent harmonic failure.
List on the fiberglass box is $86.00 that filter is $100.00 a longer one is $110.00
PM me if you are interested.
Old Oct 25, 2006 | 07:18 PM
d16dcoe45's Avatar
Don, that is the exact Pipercross setup I have for my Webers--its either KK500 or KK600--looks like the same depth too, 3.5". The standard flat aluminum backing plate is around $50 (although it looks like you are using a recessed fiberglass plate) and the filters themselves are around $100--there are also ITG which are very similar and some people think the ITG are a little higher quality. On the Pipercross website they rate the 3.5" depth ones to at least 230 hp. An advantage over Pipercross/ITG style (foam) over a generic K&N style is that since the K&N only flows from the sides--there has to be quite a bit of clearance between the mouth of the air horn to the edge of the filter--with the Pipercross/ITG, the horns can go much closer letting you fit longer air horns for better performance. Plus, there are 1/4 turn fasteners holding the foam to the backing plate--you would be stupid not to run a setup like this if you have sidedraft carbs or ITBs. The worst, as far as airflow is concerned are those "socks" that fit on each individual horn. Actually--I don't know that for a fact--but it seems to be pretty common knowledge. Hey Don, have you ever tested the "sock" type that fits on the horns versus a foam panel type versus just air horns (no filter)?
Old Oct 25, 2006 | 07:31 PM
DonF's Avatar
Default Re: Dynoed some ITB's with filters (d16dcoe45)
That is a Jenvey backing plate that they had made. Probably a bit deeper in length.I have seen the "sock" filters colapse. Especially the one's designed for go-karts bikes. A 12 BHP Briggs is still only pulling air for a 48 BHP 4 cyl. A 100 BHP bike pulls less air than a 300 BHP Honda.
Old Oct 25, 2006 | 07:46 PM
b19coupe's Avatar
Default Re: (DonF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DonF &raquo;</TD></TR><TR><TD CLASS="quote">Yes, engine dynos are useless, I just happen to be stuck with one. Wish I could get a Dyno-Jet like all the F-1 Mfg. and NASCAR engine builders use.</TD></TR></TABLE>
I hear that those guys use some dyno that costs millions-and it does everything. Simulates engine braking, starts the motor, and even tunes it for you
You need to up your equipment budget
Old Oct 25, 2006 | 07:59 PM
DonF's Avatar
Default Re: (b19coupe)
True that, just need people that will pay for it.
Old Oct 25, 2006 | 10:37 PM
92TypeR's Avatar
FSAE
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DonF &raquo;</TD></TR><TR><TD CLASS="quote">I have seen the "sock" filters colapse.</TD></TR></TABLE>
We had a sock filter rip itself in half and suck into the velocity stack, luckily it got caught on the throttle plate before doing any real damage. to sock filters.
Don, if you can do us a favor and link us to a location that sells Pipercross products, that will help everyone who is interested in this sort of filter element.
Old Oct 26, 2006 | 02:59 AM
gldndrgn14's Avatar
Default Re: (DonF)
didnt you know, "street tuning" is the only way to test the engine's abilities. haha dynos are not needed! Butt dynos are the only true test of power.
Old Oct 26, 2006 | 04:46 AM
d16dcoe45's Avatar
Default Re: (gldndrgn14)
You can buy Pipercross filters are http://www.truechoice.com
Old Oct 26, 2006 | 11:07 AM
DonF's Avatar
Default Re: (d16dcoe45)
That is the the filter. The Jenvey fiberglass "box" extends the filter out 2 inches for longer air horns.
Old Oct 26, 2006 | 12:38 PM
klungemonger's Avatar
The cost and hp loss seem like a very small price to pay for the safety of your engine...
Old Oct 26, 2006 | 12:41 PM
Rocket's Avatar
Default Re: (klungemonger)
How much power does that thing make?
Old Oct 27, 2006 | 11:47 AM
DonF's Avatar
Default Re: (Rocket)
290 BHP and 185 lb/ft of TQ with the filter.
