Passing inspection at 1/4 mile?
Old May 5, 2002 | 07:40 PM
dumbchild's Avatar
Default Passing inspection at 1/4 mile?
I relocated my battery to my trunk - but found out I can't run the 1/4 mile unless it is vented to the exterior of the car as well as having a cut-off switch on the exterior of the car
-anyone got any good ideas?
Old May 5, 2002 | 09:46 PM
CRXRageD's Avatar
Default Re: Passing inspection at 1/4 mile? (dumbchild)
are you running competition? or are you running for like a test and tune? Unless you are running in nhra sc, or idrc, or ndrc, you should have what you just said. but, I thought only professionals had to run like that.
Old May 6, 2002 | 05:20 AM
therealciviczc's Avatar
I think if you're just running street legals or test & tune, you'll get away with it, but you probably shouldn't have a non-vented battery box in your car unless you have a sealed battery. ON/OFF definately shouldn't be a problem unless you're running quick times (12.99 and lower I *think*)
Old May 6, 2002 | 06:47 AM
dumbchild's Avatar
im actually just running test and tune, but I got told that I needed all that stuff regardless - and I highly doubt i'll be pulling 12.99 - ha ha..would be nice tho.
thanks for your input.
legend99
17
Apr 24, 2012 08:01 PM
blacc_ej1
15
Dec 29, 2009 10:40 PM
logeywartooth
Sep 4, 2008 03:39 PM
manyakiexpi
Oct 24, 2006 04:57 PM
Ri5e
Feb 4, 2002 09:03 PM
