Quick Q...disconnect battery to reset radio code???
Old Oct 25, 2006 | 11:38 AM
ken00si's Avatar
Default Quick Q...disconnect battery to reset radio code???
I just replaced the battery on my Civic and pressed the wrong number for my radio code and now it is frozen. I'm assuming that I need to disconnect the battery to reset it...or can I just pull the fuse???
Any help is much appreciated. Thanks!
Old Oct 25, 2006 | 12:19 PM
philosofy1's Avatar
Default Re: Quick Q...disconnect battery to reset radio code??? (ken00si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ken00si &raquo;</TD></TR><TR><TD CLASS="quote">I just replaced the battery on my Civic and pressed the wrong number for my radio code and now it is frozen. I'm assuming that I need to disconnect the battery to reset it...or can I just pull the fuse???
Any help is much appreciated. Thanks!</TD></TR></TABLE>
you can do either one, but if your radio is freezing, i would consider replacing it.
Old Oct 25, 2006 | 12:28 PM
ken00si's Avatar
Default Re: Quick Q...disconnect battery to reset radio code??? (philosofy1)
Thanks for the info!
I meant froze because of the fact that it won't function because I did not enter the correct code.
Staz
Audio / Security / Video
Jul 22, 2010 11:52 PM
daver321
Dec 25, 2008 06:39 AM
jolt-tsp
Honda S2000
May 10, 2004 11:35 AM
cu3tip
Feb 22, 2004 07:03 PM
