Clutch question.
Have you taken your foot completely off the cluch and try again?
Sometimes it'll just be stubborn and won't go into first or reverse, and you have to give it a try or 2.
If it doesn't happen all the time or alot, then it's not something I would really worry about.
My car has trouble once in a while in reverse.
happens every once in a while; has something to do with the way the input shaft and counter shaft line up, if its misaligned after spinning down, teh synchros only help so much. I just push the clutch in/out really quick and it'll go right into gear.
