Help with a diagnostic..
I have a b16 crx dx and idle fluctuates when im in neutral. Also wen i start up the car on a cold morning it idles at around 2 (normally) and then after a few minutes it drops and starts searching for idle at 500 too 1000.
--Ive checked my coolant and thats fine.
--I cleaned out my IACV. I bled my coolant just in case of air bubbles (but i didnt lift the front end while i was doing it, I was told that was the proper way).
--I also noticed that when it is searching for idle it and the rpms drop low theres a sqeek coming from my dizzy.
--I think its my dizzy is bad. Any other suggestions before i go out and buy a new one? THanks
If the distributor squeaks then the bearings are bad. You need to replace it before it heats up and kills things inside of it leaving you stranded. I would address that first because that is definitely a big problem and could cause your problem. Id put money on the distributor being the root of the problem.
byronl
Jun 14, 2006 08:26 PM
